Old 09-14-2022, 01:09 PM   #1
VolvoLatAm
Question b21/b23 aluminum timing belt cover hardware
Does any body know the dimensions of the hardware on the b21/b23 aluminum timing covers:
-long bolts w/ washers (x3)
-extra long bolt w/ washer (x1)
-short bolts w/ washers (x6)
-bushings (x8) not including the large diameter rubber plug
-various sized metal cylinders? (x4)
https://www.ebay.com/itm/18536186096...Bk9SR9rjrs_nYA
https://www.ebay.com/itm/11550887939...Bk9SR9rjrs_nYA
Old 09-14-2022, 01:43 PM   #2
Old and boxy but good.
Sorry, I don't have any of that hardware measured. If you browse the Volvo parts catalogs on gcp.se. Many bolts have the length listed. Nothing listed in the hardware thread?
1982 242 turbo. 338k miles. MVP/ BNE coilovers and 3" exhaust. Flowed 405 with a V15T. Cossie turbine housing with upgraded compressor housing. With wildly uncontrolled wastegate. 90+, IPD remote oil filter. Some other goodness, too. Restored in 2k. Now ready for a 2nd restoration.
Old 09-14-2022, 01:48 PM   #3
The Librarian
-long bolts w/ washers (x3) bolt - M6 x 55mm / washer is special - M6 x 22mm od x 1.25mm thick Volvo part #192404
-extra long bolt w/ washer (x1) bolt - M6 x 70mm / washer is same as above
-short bolts w/ washers (x6) bolt - M6 x 16mm / washer - 6mm wave washer (only 4 required)
-bushings (x8) not including the large diameter rubber plug part #436469
-various sized metal cylinders? (x4) spacer sleeves - 2 x 40mm part #463470 / 1 x 45mm part #463538 / 1 x 60mm part #463473 NLA
Old 09-14-2022, 01:59 PM   #4
VolvoLatAm
wow thanks. literally everything.
