Old 09-15-2022, 10:25 PM   #1
sloopy
2-digit whp
sloopy's Avatar
Default removing sound deading from roof
I'm having one heck of a time removing the old sound deadening from the roof. Most of it was sagging and coming off, so I'm trying to remove it and replace it with hush mat.
https://i.imgur.com/vrj3vDQ.jpg
You can see in the picture what I'm dealing with. On the right, you see what happens as you try to peel the stuff off. Some of the paper stuff stays adhered to the roof. On the left, you see what happened after I tried to use heat to soften things up. I also tried this 303 adhesive and decal remover (which is some really nasty stuff I'd rather not use anymore) and came up with similar results. Haven't tried goo gone yet. I'm thinking I might try dry ice next.
How thoroughly do I need to get the old adhesive off? I want the new stuff to stick really well. Any suggestions on removing this stuff?
1992 volvo 240 wagon: black
> engine: b230f, a-cam, tube header
> drivetrain: m47ii, 4.10 gear, wavetrac lsd
> front suspension: bne coilover, 200 lb/in spring, koni sport damper, bne qsrc v2, bne strut mount, 23 mm bar
> rear suspension: lesjofors 131-188 lb/in spring, koni sport damper, 19 mm bar
> wheel: 15x7 multi-x
> tire: 225/60R15 bfgoodrich radial t/a
> misc: 6 lb lithium battery
sloopy is offline   Reply With Quote
Old 09-16-2022, 02:51 AM   #2
MaTus_SVK
MaTus_SVK's Avatar
I ve had great success with rubber attachment on drill like this one when removing old adhesives from inside of the car, rubber tire valve in drill works as well it just really small area of effect buut its cheap and always at home solution.
https://www.amazon.com/Dent-Fix-Equi.../dp/B00JVK587A
MaTus_SVK is offline   Reply With Quote
Old 09-16-2022, 10:34 AM   #3
sloopy
2-digit whp
sloopy's Avatar
Is the textured rubber wheel like that one a lot better than the solid ones for something like this? I have a solid rubber wheel and it seemed to just smear the adhesive around. Maybe I didn't press hard enough. Also, I used the solid rubber wheel last night to start removing the gold pinstripe and it made an unbelievable mess of rubber dust. I guess I need someone to operate the vacuum while I work with the wheel.
Old 09-16-2022, 12:54 PM   #4
mblue240
mblue240's Avatar
If it's just sticky adhesive that's left I'd apply the new sound deadner right over it. As for the eraser wheel, the idea behind the slotted one is that it runs cooler. I watched a video that debunked it, so I'm still using a solid one with no issues. Every so often I just brush the dust away with my hand and keep moving.
Old 09-18-2022, 12:46 AM   #5
sloopy
2-digit whp
sloopy's Avatar
Dry ice didn't help much either. At least it was fun to play with. The best I can do is scrape the adhesive to as thin a layer as I can with my metal scraper. I hope the hushmat sticks to it well.
Old 09-19-2022, 12:42 PM   #6
mblue240
mblue240's Avatar
I put the hushmat on with a roller, park it in the sun, then roll it again. The tar stuff is super sticky after it heats up. I'm pretty sure once you use any of the Dynamat type products they're on for life.
Old 09-19-2022, 02:27 PM   #7
Corey
Corey's Avatar
An abrasive wheel/rust removal wheel with a grinder usually works
sig pic
Corey is offline   Reply With Quote
Old 09-19-2022, 05:41 PM   #8
- Stock PSI Or Bust -
how psi stock cna sprout?
