Old 09-17-2022, 05:06 PM   #1
Old and boxy but good.
Default Tire softener
Have any of you used these tire treatments? Any good? I have a set of Potenza
SO 3 that have good tread but are kind of old.
https://www.ebay.com/itm/26510042366...Bk9SR9LyiNTpYA
https://www.ebay.com/itm/38335112734...3ABFBM0vKI1Olg
Those are two I looked at. They also have Stripper Glitter and Hot Lap brands.
What do ya think?
For some background at work we used to use Fedron to revitalize rubber platens
on the old teletype and Extel printers. That stuff worked great but seems very
limited in supply now.
1982 242 turbo. 338k miles. MVP/ BNE coilovers and 3" exhaust. Flowed 405 with a V15T. Cossie turbine housing with upgraded compressor housing. With wildly uncontrolled wastegate. 90+, IPD remote oil filter. Some other goodness, too. Restored in 2k. Now ready for a 2nd restoration.
Old 09-17-2022, 09:03 PM   #2
apachechef
Burnt Sierra Madre
lol
Dammit, Lummert.
apachechef is online now   Reply With Quote
Old 09-18-2022, 10:57 AM   #3
OldCarNewTricks
OldCarNewTricks's Avatar
What do ya think?
From my understanding, and what I was taught in class, they will all be snake oils. The oils in the rubber come to the surface with regular use, but will eventually "dry out." When they are worn, they are worn and must be replaced. I would reccomend the safe option, which is replacement of the tire. Safer for you, and safer for the car they are mounted on
OldCarNewTricks is offline   Reply With Quote
Old 09-18-2022, 11:22 AM   #4
HiSPL
Fanking Champion 1993
HiSPL's Avatar
IDK how similar Karting tires are to street or track tires, but nobody uses softener at the kart track. It seems to work once, then that tire is done and needs to be changed (to stay competitive).
We wrap our kart tires in cling wrap for storage. Makes them stay sticky for longer. Wrap them at the end of a race day and keep it on until next race.
Beets taste like buttfeet.
Originally Posted by 240 240 View Post
water-cooled VW owners can't even tell you the flavor of Cheetos they ate last night.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
96 960 (rotted)
88 244
06 XC90 V8
03 V70(crashed)
92 745 Turbo
Old 09-18-2022, 03:38 PM   #5
culberro
culberro's Avatar
They work. Some better than others.
I’ll reach out to those I know that do this, and see what they’re using. I see that Pegasus sells a tire softener, and the bottle looks familiar to what my friends were using.
Toluene also works.
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 09-18-2022, 05:08 PM   #6
Long ago to soften the platens on the printers we used Fedron which the main ingredient was xylene. If you forgot a platen and left it in there overnight it would swell and get stuck in the can. So I figured some one here must have tried a similar tire treatment. It's just for street tires but I hope to get a bit more use out of them. Those Potenza S03 tires were expensive.
Thank you for the replies.
Old 09-18-2022, 05:17 PM   #7
alschnertz
Enough already!
alschnertz's Avatar
I wonder if I could use it on the snow tires I got suckered into buying in 1989 for the 740. They were used 2 winters and have been stored in the cellar since.
(Honestly, they still look new.)
Old 09-19-2022, 09:08 PM   #8
kyote
Living The Dream
kyote's Avatar
Xylene would be the ticket I'd think.
I would recommend wearing gloves.
-06 Camry SE 2AZFE
-14 F150 FX4 3.5 EcoBeast
What Kyote sez, more or less
Old 09-20-2022, 12:24 PM   #9
culberro
culberro's Avatar
This or toluene is the cheap way to soften up some rubber... but with the cost of solvents these days, new tires might be cheaper
Old 09-20-2022, 12:33 PM   #10
esmth
Somewhat related, I once sprayed a tire with a ton of fluid film, and 24 hours later the tire must have absorbed it because it was completely gone and it looked bone dry. I avoid the tires when spraying the car now
1991 244 LH3.1 M46 402k miles
Old 09-20-2022, 01:08 PM   #11
I browsed buying Xylene and it's quite pricey. About 100$ a gallon similar in price to the tire softener. I'll think about it. Probably get the tire softener to try if I buy something.
Old 09-20-2022, 02:16 PM   #12
Khrrck
Professional Amateur
Honestly I'd be concerned about the structural integrity of the tire once you start painting chemicals on it. Xylene is also a nerve poison when inhaled and with the quantities required to cover 4 tires, I'd say a respirator, good ventilation and correctly rated gloves would be a minimum.
'87 240 budget wagon. Sadly departed.
'88 240 eggshell wagon.
Old 09-20-2022, 02:57 PM   #13
culberro
culberro's Avatar
Maybe this?
https://maxtorqueperformance.com/ind...tment-1-quart/
Old 09-20-2022, 04:43 PM   #14
Looks like a good product. Thank you.
I really don't want to use the Xylene since it is such a dangerous chemical. I breathed in enough of that stuff 30 years ago when working with all those old printers.
Old 09-20-2022, 08:22 PM   #15
Khrrck
Honestly most things that absorb into and soften rubber that easily are gonna be pretty nasty solvents.
Old 09-21-2022, 06:55 PM   #16
283SD
Clorox
Old 09-22-2022, 12:20 PM   #17
Stiggy Pop
Stiggy Pop's Avatar
eh? I use Xylene for paint projects it's like $20/gal at the hardware store.
'79 242
943 pickup
Old 09-22-2022, 12:43 PM   #18
That's great. I guess I'll shop around a bit. Thanks for the info. No more local
hardware stores around here anymore. I guess I was just seeing the ebay top
dollar pricing.
Old 09-28-2022, 03:44 PM   #19
Stiggy Pop
Stiggy Pop's Avatar
dollar pricing.
ah yeah that makes sense, prices on "chemicals" online can get crazy; I think due to hazardous material shipping and handling etc. I was running some xylene through the paint gone just a few weeks ago (with an n95 respirator on...).
Old 09-29-2022, 12:54 AM   #20
sbabbs
sbabbs's Avatar
My bottle of MG chemicals Rubber Renue says it has Xylene, Ethyl benzine, Methyl Salicyate. I use it to soften up reel to reel tape deck capstans. Says don't breath, warning Cancer..
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 555K
1995 940 White racing wagoon. 13c.
