Old 09-20-2022, 09:44 PM   #1
Yeedogga
Yeedogga's Avatar
Default Rear wheel play and clunk with handbrake / e-brake on
Hi brickers,
Unsure whether this is just a #Volvothings, or if something is wrong.
240 sedan with all new rear poly bushings, adj torque rods, panhard bar etc. The bushings were all tightened with the car at ride height.
Handbrake/e-brake cables are adjusted properly and stop the car without excessive lever travel
With car on stands and handbrake on, you can rotate the rear wheels a small amount each way and they clunk at each end.
The same noise can be heard with an aggressive downshift or when reversing from a stop (the noise seems to transmit through the tailshaft making a 'ting' noise).
There is minimal play in tailshaft when handbrake is on
Any ideas?
Chris
1983 240GL - 1UZ-FE - in progress
1985 240GL - SOLD
1985 760 Turbo Wagon - SOLD
Yeedogga is offline   Reply With Quote
Old 09-20-2022, 10:20 PM   #2
Nagrom
Nagrom's Avatar
How're the transmission&motor mounts?
Nagrom is offline   Reply With Quote
Old 09-20-2022, 10:38 PM   #3
Yeedogga
Yeedogga's Avatar
Brand new engine and trans mounts. Nice and solid
Old 09-21-2022, 01:57 AM   #4
MasterBlaster
MasterBlaster's Avatar
That part is normal. At rest, the ends of the parking shoes are both against the "stop". When you pull the handle, the shoes are spread until they contact the drum. There is now a gap between the shoes and the stop. The drum/shoe/shoe assembly will rotate until one of the shoes contacts the stop, and you... stop.
The same noise can be heard with...
I would say that's a different noise, as the shoes aren't doing anything unless the handle is pulled.
1990 740GL
545,000 km so far...
Old 09-21-2022, 05:01 PM   #5
Old and boxy but good.
How are the driveline components? Stuff like the ujoints and support bearing? Also make sure the rear axle is full of oil.
