Old 09-20-2022, 10:37 PM   #1
DD Ranch
DD Ranch's Avatar
Default HVAC tubing source?
The vacuum tube from the manifold back through the firewall to the heater box that controls the vents, has somehow shrunk on my 91 240. So I think it best I replace the whole length.
Local Hose and Hydraulics don't have tubing that small. Anyone know of a source or even the actual internal diameter. I know the ext dia is 5mm.
Thanks.
Florida Chapter VCOA
DD Ranch is offline   Reply With Quote
Old 09-21-2022, 12:54 AM   #2
bgpzfm142
crossmember
bgpzfm142's Avatar
That hose is p/n 943999.
OD is 6.5mm
ID is 2.5mm
Volvopartswebstore and some others have it listed as available.
_______ THE FLEET (AKA good luck trying to park around here)
71 1800E | 73 144 | 74 142 | 74 145 | 79 242GT | 85 244 | 88 780 V6 | 93 945T | 96 965 | 2010 S80 V8
plus a Holden Commodore VT SS 5.7
feedback thread
bgpzfm142 is offline   Reply With Quote
Old 09-21-2022, 07:13 AM   #3
tjanson
tjanson's Avatar
Is this the plastic tube/hose? Belmetric has a few sizes of small polyamid tube, M2x4 and M3x5. One of those might work if you don't want to use the Volvo PN.
https://belmetric.com/m3x5-black-polyamid-hard-plastic-rhpoly3-3011-0305/
1993 245 DL - OEM+ Project
tjanson is offline   Reply With Quote
