Old 09-22-2022, 09:05 PM   #1
VolvoLatAm
Default titanium intake/exhaust manifold stud kit
https://www.ebay.com/itm/11507715751...EAAOSwUblfUB22
anybody on here used these titanium INTAKE / EXHAUST manifold studs...?
Old 09-22-2022, 09:20 PM   #2
Khrrck
Professional Amateur
Why do you want titanium? It's stronger per weight, yes - but since they aren't any larger than the stock steel, they'll be weaker. And the price is outrageous!
'87 240 budget wagon. Sadly departed.
'88 240 eggshell wagon.
Old 09-22-2022, 09:31 PM   #3
Jack
junkman
Jack's Avatar
Pooping before driving will save more weight
I love you even more Jack.
Old 09-22-2022, 09:32 PM   #4
Dan
Fought Covid and won
Dan's Avatar
Doing a little googling and ran across this. Dissimilar metals such as a titanium exhaust manifold bolt and the softer aluminum head do not work well together, especially when exposed to extreme heat, cold or road debris like salt. A chemical reaction takes place which essentially welds the two components together
Combine these two risks, and the situation can become extremely difficult when a gasket is being replaced and the titanium bolts on the exhaust manifold break due to their loss of strength and inability to back out of the threads in the aluminum head.>
1985 Chevy TPI V8 740.
Old 09-22-2022, 09:39 PM   #5
VolvoLatAm
LOL not going to buy these. Just curious why he would make them
Old 09-22-2022, 09:40 PM   #6
VolvoLatAm
muy interesante
Old 09-22-2022, 09:41 PM   #7
VolvoLatAm
are we talking Elvis weight savings
Old 09-22-2022, 09:41 PM   #8
Dan
Dan's Avatar
Found this on a 911 forum
"We have made a batch of Grade 5 Titanium studs and some matching nuts.
These have about the same strength as a Grade 10.9 bolt and they will be difficult to break.
They have a 'dog point' on one end so they can be gently tightened into the head and then held in place with Loctite 266 which is a High Temperature thread locker.(this will be supplied with stud kits)
The opposite end of the stud is prepared with a 4mm AF socket head to allow tightening.
The threadlocker will also electrically insulate the threads and prevent bi-metallic corrosion."
Old 09-22-2022, 09:54 PM   #9
Khrrck
Because they can make money.
Old 09-22-2022, 10:07 PM   #10
Jack
junkman
Jack's Avatar
Everyone knows titanium bolts are the key to finding her g spot
