Old 09-22-2022, 09:39 PM   #1
HiSPL
Fanking Champion 1993
HiSPL's Avatar
Default 91 740 Fuel Return. What am I missing?
The return line at the back of the car. How do connect this:
To this:
The factory hard pipe is about 1/2" OD, but the barbed fitting on the fuel pump is 1/4". It's a banjo fitting though. Is there some Volvo part I'm missing here? The previous owner had a kluddge of brass fittings to adapt it down to 1/4", but the old 1/2" fuel hose basically just fell apart. It's probably old hose not rated for gasahol. I temporarily fixed it with some heater hose, but I'd like to do this properly. Unfortunately I haven't found the part online yet. Doesn't help that I don't even know what I'm looking for.
Does the hard pipe accept a clip-on type fuel fitting?
Beets taste like buttfeet.
Originally Posted by 240 240 View Post
water-cooled VW owners can't even tell you the flavor of Cheetos they ate last night.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
96 960 (rotted)
88 244
06 XC90 V8
03 V70(crashed)
92 745 Turbo
Old 09-22-2022, 11:36 PM   #2
HiSPL
HiSPL's Avatar
The best thing I can think of right now is to take the banjo bolt out and replace it with a 1/2"npt to 1/2" barb fitting. Then I could just use 1/2" fuel hose all the way.
Just sucks that I can't get any of these things in town.
Old 09-23-2022, 01:34 AM   #3
MasterBlaster
MasterBlaster's Avatar
Except banjo bolts are straight thread, and NPT is tapered.
Either it won't thread in properly at all, or expect a leak.
1990 740GL
545,000 km so far...
Old 09-23-2022, 08:58 AM   #4
Urvanej
Just buy the banjo union in the right size for the hose that fits the other end.
But to be honest, I never saw the banjo fittings there. Maybe some 91MY speciality.
Urvanej is offline   Reply With Quote
Old 09-23-2022, 10:58 AM   #5
oldschoolvolvo
oldschoolvolvo's Avatar
You may be able to find a banjo fitting that has a barb with a closer match to the hard line and will allow you to run a single piece of rubber fuel line between the two.
https://belmetric.com/fittings-plugs/banjo-fittings/
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 09-23-2022, 12:45 PM   #6
HiSPL
HiSPL's Avatar
Yeah I guess that's the solution to my particular problem.
The weird thing is that I can't find the part that's supposed to go there on any parts site. I don't have VIDA anymore and can't look it up. And also this fuel pump dosn't look like what I see on the internet either. It works though, as does the level sender.
I was told that this car ran over a bear about 100k miles ago and that some stuff underneath was fixed/replaced. When we bought it (a year ago) the main pump was whining. I figured out that the tank pump simply didn't have power. fixed the break in the cable and all has been well until this leaking started.
Old 09-23-2022, 01:00 PM   #7
philski o'flood
philski o'flood's Avatar
well there you go
philski o'flood is offline   Reply With Quote
Old 09-23-2022, 01:31 PM   #8
HiSPL
HiSPL's Avatar
I don't know how big Mr. Bear was, but I can tell you the 740 handled it like a champ! This is a very straight car still.
