QisofrKuin
- Feb 19, 2021
- Dallas, TX
Hello all,
I have been scouring the many bits of info about various charging issues but haven't found one matching my issue yet, so thought I'd put this out.
My '81 244 DL is not charging the battery, but the battery indicator light is not coming on. This is not the only thing on the dash that doesn't work--neither the clock, nor temperature gauges work, and when I turn the key to the "on" position only the parking brake light comes on. This was not the case when I bought the car a few months ago, at which point the lambda-sond light would also come on, and the clock worked (not the temperature gauge though). The gas gauge, parking brake light, and overdrive light all still to work.
Now, my question is whether some bad connection to the dash could be preventing the alternator from charging the battery, as I seem to have read that the circuit passes through the warning light. I have checked the fuses and the grounds and they all seem good. I looked at the alternator brushes and they seemed plenty long with good, smooth surfaces. I'm worried that I'll buy a new alternator and not have it fix the problem, so any advice is welcome
Thanks
Thanks
