dandeluca
- Jun 17, 2020
- Bordentown NJ
I am in the middle of swapping an older M46 into my 91 245 automatic. The bell housing on my M46 does not have a cut out or 'thin spot' for the crank sensor. My original plan was to replace the bell housing with one that did have the cut out. However, I was reading that each bell housing is shimmed individually to the transmission.
Do you think it's worth swapping it or should I just cut into the bell housing I have?
Also I wanted to remove the bell housing to replace the front seal. I took out the 4 bolts and the snap ring at the base of this sleeve.
Does the sleeve pull out or does the bell housing slip over it?
