Old 08-01-2020, 11:05 PM   #1
92White240
Default Hydra center cap question
I like the look of Hydras without the centercaps so you can see the lugs but I don't like the hub exposed, is there any small centercaps wether it be on IPD or from other wheels that fit in the small center hole?
92White240 is offline   Reply With Quote
Old 08-01-2020, 11:37 PM   #2
set of 4 VOLVO 850 S60 S70 S80 V50 V70 XC70 XC90 Black Wheel Center Cap 3546923
how psi stock cna sprout?
Old 08-02-2020, 01:44 AM   #3
Tsayloco
Tsayloco's Avatar
Redwood has the hook up. If you want to gamble and be a bit different you could search 65mm centerbore wheel caps on Google for a hand full of generics. The Volvo center bore is 65.1mm. I wouldnt expect any of them to reliably lock in without a little adhesive or tape.
Tsayloco is offline   Reply With Quote
Old 08-02-2020, 09:32 PM   #4
I've got a set here TB¢heap as well.
Old 08-02-2020, 10:15 PM   #5
S70T5fivespeed
Its always 7:4O somewhere
S70T5fivespeed's Avatar
You should run it with no hood so you can see the engine thingy too
99 S70T5M black on graphite
91 740SE white on black
90 740TI black on checkers
In the barn: 67 123GT
S70T5fivespeed is offline   Reply With Quote
Old 08-02-2020, 11:38 PM   #6
Virgo and Corona center caps fit too but they're spendy.
Old 08-03-2020, 09:30 PM   #7
nel621
I don't have Hydras but not sure the Virgo cap will fit the bearing cap. I know it doesn't work with Corona wheels. Also the black cap barely works with Corona wheels. Perhaps the Hydra hub is different????
Old 08-03-2020, 09:31 PM   #8
nel621
Old 08-04-2020, 04:56 PM   #9
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Corona caps look best.
-J
@john242ti on IG
