Old 02-23-2016, 02:55 PM   #1
turbotankshane
Default 3.35 input shaft for t5 tooth count
I've been looking on ebay for a new input shaft, none list the actual gear ratio, just a tooth count. Anyone know the correct length and tooth count for a 3.35 first gear t5 input shaft when using with a deeworks adapter?
Old 02-23-2016, 02:56 PM   #2
cwdodson88
I thought it was a 23t, but I'm not sure, in the same boat.
The Build Thread
SVEA - PUSHROD TURBO!
Old 02-23-2016, 03:03 PM   #3
gsellstr
gsellstr's Avatar
I think it's a 23T as well.
Call up Astro Performance, buy one from them. The chinabay ones have some issues with wear. My new Tremec one from Astro was around $110.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-23-2016, 03:07 PM   #4
turbotankshane
It would be extremely nice to know the correct length, as my trans ID tag came up as a 2000+ v6 car, but it had been used in a 95 v8 car before I bought it. So probably still not the correct length but it may have been changed. Mustang forums don't bring up anything concrete either.
Old 02-23-2016, 03:13 PM   #5
centason
Autogestion
centason's Avatar
3.35 with the 59/27 gearset
Input shaft - 23 teeth
countergear - 34 teeth
5th Large gear - 59 teeth
5th Small gear - 27 teeth
http://www.stangnet.com/mustang-foru...ome-in.666860/
This may help? Disregard the arrow.
Member: TBCCS
"Those who do not move, do not notice their chains." -Rosa Luxemburg
Old 02-23-2016, 03:19 PM   #6
cwdodson88
9,1/16" or 9.25" I think...
Old 02-23-2016, 04:43 PM   #7
gsellstr
gsellstr's Avatar
Unless it was in a Fox, chances are it's wrong. The SN95 body style had a longer shaft and bellhousing to match, as their means of shifter positioning.
I have a known SN95 shaft at home that I can measure and count the teeth on, came from a 95 5.0 3.35 1st box.
Old 02-23-2016, 05:05 PM   #8
turbotankshane
I did get a chance to run by the house on lunch and measure , but since its got a 3.8l bell housing on it and the tip of the input shaft protrudes past that I'm sure its incorrect. So I'm ordering a 23 tooth 9.25" input shaft that's listed as being for 85-93 5.0 mustang.
But if you'd like to count just so we all have some peace of mind on the subject, that'd be fantastic.
Old 02-23-2016, 05:21 PM   #9
gsellstr
gsellstr's Avatar
I will try and get that on the roster for tonight.
Old 02-23-2016, 06:02 PM   #10
Maxdabreaker
Maxdabreaker's Avatar
http://www.thegearbox.org/contact.html
I bought a WC T5 rebuild kit from these guys, absolutely amazing service, I'd contact them.
Maxdabreaker is offline   Reply With Quote
Old 02-23-2016, 06:40 PM   #11
towerymt
the real Towery
towerymt's Avatar
tip for all: make sure you have the correct front bearing cover. the ford motorsport part with the steel collar is what I used on my car. it's meant for the fox V8 input shaft length. But on our lemons car, we ran into an issue when trying to use the V6 bearing cover with the sleeve cut down to match the height of the fox V8 cover. we had swapped to the v8 input shaft, but retained the v6 bearing cover.
At the base of the sleeve, the aluminum part of the bearing cover protrudes further out from the front of the transmission. it hit against the release bearing and partially disengaged the clutch.
Unfortunately I wasn't there when it was all put together, because I found out later that the trans didn't mate up to the adapter plate until it was pulled in with the bolts (bad juju), which should have been a sign that something was wrong. Indeed, the first ~20min of the first stint of the race was spent limping the car around, trying to diagnose what could be wrong....why does the clutch not hold from a roll in 2nd gear? will it get better if I keep driving it??? nope! we found out the hard way. lost 2-3hr track time pulling the trans, realizing what had happened, and swapping in out spare that had the correct bearing cover already on it.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 02-23-2016, 06:41 PM   #12
turbotankshane
Thanks Max!
Old 02-24-2016, 01:59 AM   #13
gsellstr
gsellstr's Avatar
23T, 9.25" from the backside of the gear to the tip.
Old 02-24-2016, 03:05 AM   #14
turbotankshane
You're the man. Got one ordered!
Old 02-24-2016, 05:28 PM   #15
RallyRat
RallyRat's Avatar
I have one from a -260 tag number box. 23 teeth, 10" overall length (9.25" to the back of the gear). This is longer than what most people use for transmission swaps. I made my own adapter plate that is about 1.25" thick and the pilot almost bottoms out in the crank shaft bore; most adapters out there are around 1/2" thick.
RallyRat is offline   Reply With Quote
Old 02-24-2016, 05:36 PM   #16
Lord_Athlon
300+ Clurb
Lord_Athlon's Avatar
Did it fit in the tunnel with the extra length?
Yet Asher here went with...
Old 02-24-2016, 07:22 PM   #17
turbotankshane
The 260 box is what I have, that's why I'm swapping out the shaft.
