#1 |
![]() Are there any electronic ignition kits for the B16? It has been changed to 12 volts.
#2 | |
![]() Pertronix works on just about anything as a points replacement.
The Build Thread SVEA - PUSHROD TURBO! |
#3 | ||
Cretin
![]() I bought from here this summer for an old inboard ski boat, very quick shipping!
https://vintageperformance.com/retrorockets/index.html
#4 |
![]() If I recall correctly the B16 distributors use the same points setup as the early B18 cast iron ones. So a pertronix module should fit just fine.
I'd take apart and lube the distributor and inspect for wear while installing a points replacement. |
#5 |
Old and boxy but good.
![]() I just sold my last cast iron distributor pertronix recently. The part number was 1844.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 440k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
#6 |
Cretin
#7 |
The Librarian
![]() B16 distributors use different points so I don't think the 1844 will work. VP sells a 2843N6 for the 6 volt cars so I would assume that the 12 volt version 2843 would work.
https://pertronixbrands.com/products...31797263106084 123 ignition also makes a distributor for B16 engines that will work with both 6 and 12 volt systems. https://vp-autoparts.com/en/artiklar...3-b4b_b16.html |
#8 |
![]() Join Date: Dec 2006
![]() I did the drop in upgrade in my redblock boat, but then the tach didn't work. Boat runs great!
#9 |
![]() May thanks for the information
Thread Tools | |
Display Modes | |
