Old 03-07-2022, 10:12 PM   #1
2 old for this
Default How to ld b230 head
Is there a part / casting number on the cylinder head that tells if it is a turbo or non turbo
Old 03-07-2022, 10:51 PM   #2
No. Look at the exhaust valve head in the combustion chamber. If it is a turbo head there will be a slight dimple in it right in the center. That’s the only difference. The turbo heads use sodium filled valves.
Old 03-08-2022, 09:19 PM   #3
2 old for this
Thank you
Old 03-08-2022, 10:38 PM   #4
hessam69
Other than the above, there is no difference in the 1000530 heads turbo or NA, only the turbos got the sodium filled exhaust valves
