Old 03-18-2013, 02:08 AM   #1
TracksideTurbos
TracksideTurbos's Avatar
Default Triple C's Toner
So about 2 years ago I picked up my 1980 Volvo 262c Bertone from my boss for $300 bucks.It had been sitting in the yard for about 10 years when I got it
It just so happens that a guy had done a little write up on the history of the 262c's and my car was used for his pictures http://www.curbsideclassic.com/curbs...n-translation/.
Right away I started in. First I got the b21f my boss had swapped in11years prior running. It needed a head,fuel pumps/relay,fuel tank/sender and some love. Next was the suspension it got Triple C shortend adjustable coilover struts w/rsi race billies,Triple C adjustable torq rods,Triple C adjustable pan hard bar,Triple C rear spring adjusters,revalved s10 billies,ipd 25/25 sways,gt strut plates and some Triple C strut braces and subframe ties.
After about a year I decided to put in my b230f+t squirter from a previous project. It has a port/polish,38mm exhaust valves,ipd cam/pulley,ported 90+,ebay t3t4 w/atp ultimate wastegate housing,99 npr,greddy bov,43# injectors,4bar fpr and my ms2 spark n extra. Then I built a new Triple C 3in exhaust and I was down the road. Over the last year I got a few things for it like an r sport cluster,early e-codes and clear lights..
So about 2 months ago I decidedto get rid of that ugly ass gold paint and put in a b230ft+16v. First the interior comes out and I found this in the rear and a little rot in the floor. So far I have welded up all the 100+ trim holes and the extra holes under the hood. About a week or so ago I got my new wheels and tires and did a test fit.. I think they look good. Last weekend I sand blasted all the rust and treated it. Now I have to fix the roof/body seam. So now we are up to date.
TracksideTurbos is offline   Reply With Quote
Old 03-18-2013, 03:39 AM   #2
2fast242gt
Do you have a cobalt?
wow weird place to rust out! i normally dont like bertones, this one looks great!
1983 242dl
*6.0 lq4 swaped* Build thread
Old 03-18-2013, 07:55 AM   #3
242 glt
242 glt's Avatar
Triple c struts, lol
1983 242 m46
1985 245 ti m46
1967 Plymouth GTX HT, 4spd, 360, 391 posi, daily driver.
1964 Plymouth Valiant 2d post, Welded frame conn, torque boxes, super slant 6 project, now daily driver. 1992 cummins 4x4 5 speed
1978 1/2 ton
242 glt is offline   Reply With Quote
Old 03-18-2013, 10:19 AM   #4
TracksideTurbos
Thanks. I have 2 more Bertones and I hope the are not rotten in the same place. My bertone had pieces of foam stuffed in the rear pillars and a roof trim clip touching it. Just wicked in the water.
Old 03-19-2013, 02:49 PM   #5
dustingt242
Nice looking car..glad I've got all those triple c goodies under my gt..keep up the good work
dustingt242 is offline   Reply With Quote
Old 03-19-2013, 10:39 PM   #6
242 glt
242 glt's Avatar
Toner.
Old 03-19-2013, 11:43 PM   #7
M.H. Yount
M.H. Yount's Avatar
Not uncommon for Bertone's to have corrosion problems related to the roof...
Old 03-22-2013, 10:13 PM   #8
TracksideTurbos
I got in my new bucket seats and they are way nicer than the standard Volvo buckets but not near as comfortable. I guess I will have to open them up and ad a little cushion in the lumbar area.
Old 03-23-2013, 12:06 AM   #9
TracksideTurbos
So I have been busy and haven't had time for much. I did get one side of the roof trim water catch all welded in this week using metal from an old 240 fender but first I had to stitch the panels together because that seam is a weak point and flexes really bad and I don't want any cracks developing in the filler. Tomorrow I'll be back at the shop doing the other side and the inside roof pillers.
Old 03-23-2013, 10:22 AM   #10
pwschuh
Rolling...
What seats are those?
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 03-23-2013, 11:21 AM   #11
thelostartof
unbalanced chemical
thelostartof's Avatar
they look like corbeau a4/baja xrs with a custom cover, but at the same time they look like most all seats so it could be anything
Great progress, wish could semi restore my shell like that
Old 03-23-2013, 01:40 PM   #12
doucheNozzle
doucheNozzle's Avatar
Looks good. Ditch those awful rear taillights though.
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
‘12 Mazda5 - Work Car
‘06 E350 Ambulance - Work Car
Old 03-23-2013, 02:03 PM   #13
TracksideTurbos
The seats are summit sport buckets. Some people do not like the clear tail lights and to be honest I am not a big fan of the clear but they look sweet tinted. I will post some pics when I get home from the shop.
Old 03-24-2013, 09:38 PM   #14
TracksideTurbos
So over the last couple of days I got futher along. I finished welding in the trim patch.
With that done and out of the way I can start patching the inside pillers. First I made a cardboard template.
Then I traced out a couple of patches and cut them out with an angle grinder with a cutting disc.
Now for the fun. I start with tack welds on the top edge add a little heat and hammer to fit
So all the roof rot is all patched and strenghend. This week and coming weekend I will tend to the floor rot.Even though it doesn't look that bad it is bad enough. I think this will be the hardest part since there are multiple layers of metal and rotted around the unibody frame.
Oh and here is a pic of tail lights I had a buddy tint for me. I think they will look nice against bright red paint.
Old 04-12-2013, 12:21 AM   #15
TracksideTurbos
I started with cutting all the spot welds from the donor seat pan and well I really aggrivated ye ole quad shoulder injury and has taken several weeks to come back from that, well somewhat.
So last weekend I did get half the seat pan out of the Bertone and exposed the passenger floor. This is definitely the hardest part of the resto for me. Cutting all those spot welds suck but hey no pain no gain.
Old 04-12-2013, 12:35 AM   #16
frodosm3
frodosm3's Avatar
impressive
1976 Volvo 242DL Holset HE351 16 Valve
1983 Volvo 242DL New Daily
1993 Volvo 244 For Sale
1966 Volvo 122S Amazon
frodosm3 is offline   Reply With Quote
Old 03-19-2014, 11:30 PM   #17
edgar333
edgar333's Avatar
are the wheels 16x9?adapters or re-drilled?
looks great btw
1989 wagon 245
1984 242
edgar333 is offline   Reply With Quote
Old 03-20-2014, 12:39 AM   #18
2fast242gt
Yeah those look great what are they?
Old 03-20-2014, 12:55 AM   #19
edgar333
edgar333's Avatar
http://esmwheels.com/access/sportlic...r-c-21_91.html top rightt
Old 03-20-2014, 06:12 PM   #20
amerbritcan
Hnnnnnng
amerbritcan's Avatar
Any progress on this build?
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 03-20-2014, 09:35 PM   #21
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
The tail lights are still ugly....wheels are sick though
Deb the 940T Tina XC90 T5
