Old 12-15-2021, 03:30 PM   #1
propav8r
F*ck Edgar
propav8r's Avatar
Default SC-811 Amplifier?
Hey, so I have a 95 960 that has the SC-811 radio in it. It sounds...really bad. The weird part is that it sounds way worse when the car has been sitting overnight in the cold, and it starts to sound a bit better as the car (or radio? Or amp?) warms up.
Currently I only have audio in the front door speakers, and only barely at that.
I'm seriously considering ripping everything out and building an audio system for this thing since that's all you can REALLY do with a 960 anyway without a huge amount of effort.
But I figure I may put a little effort into fixing the stock system before I go whole hog.
Which brings me to the actual question...did the SC-811 head unit use an amp? I'm wondering if maybe the head unit is fine but the amp is dying.
If there's no amp, it's probably something screwed up in the head unit.
Originally Posted by 1968 volvo View Post
Tb's ot is a great place full of happy people who want to be your friend. The content of ot is always wholesome and no one ever gets angry or upset. Ever.
My Project
K-Jet to Megasquirt Article
Old 12-15-2021, 03:35 PM   #2
2manyturbos
Have you pulled the stereo out and looked for a cable running to an amp? I'm looking at one of the 960 factory stereos right now and there is a cable socket on the back of it labeled amp.
Old 12-15-2021, 03:42 PM   #3
propav8r
F*ck Edgar
propav8r's Avatar
Nope. That would've been too easy.
Lemme go do that.
Old 12-15-2021, 03:49 PM   #4
propav8r
F*ck Edgar
propav8r's Avatar
No amp connection, so looks like the head unit is junk. It's pre-wired for a CD changer though, so that would be awesome if it was 1996.
Old 12-15-2021, 05:12 PM   #5
rearwheelpeel
Slow Learner
rearwheelpeel's Avatar
I’m pretty sure the stock head unit in a 95 960 comes with a built in amp. It’s not a separate unit. That being said, mine always sounded pretty great, but it was owned by an old lady before me who only listened to npr.
rearwheelpeel is offline   Reply With Quote
Old 12-15-2021, 07:49 PM   #6
swedishiron.com
I sell Volvo parts!
You can also upgrade the SC-811 to SC-815 (which also has an internal amplifier).
I sell tested units for $50 shipped if you want to buy one.
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
Old 12-15-2021, 08:37 PM   #7
2 old for this
My 240 has a Sony head unit that is about a year old and have similar problem. Does not have a amp. Different temperature causes different sound quality.
Old 12-15-2021, 11:47 PM   #8
HiSPL
Fanking Champion 1993
HiSPL's Avatar
That''s typically indicative of corrosion in/on connectors or grounding points in the PCB. a little skin of corrosion forms, then as you put some voltage through it, or heat it up the stuff moves around and either starts making better contact or it doesn't.
Beets taste like buttfeet.
Originally Posted by 240 240 View Post
water-cooled VW owners can't even tell you the flavor of Cheetos they ate last night.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
96 960 (rotted)
88 244
06 XC90 V8
03 V70(crashed)
92 745 Turbo
