![]() Is there a part / casting number on the cylinder head that tells if it is a turbo or non turbo
![]() No. Look at the exhaust valve head in the combustion chamber. If it is a turbo head there will be a slight dimple in it right in the center. That’s the only difference. The turbo heads use sodium filled valves.
![]() Thank you
#4 |
![]() Other than the above, there is no difference in the 1000530 heads turbo or NA, only the turbos got the sodium filled exhaust valves
