Old 03-12-2022, 09:33 PM   #1
TheVolbro
The Collector
TheVolbro's Avatar
Default 1984 240 steering wheel removal HELP PLEASE
How do I remove this steering wheel without damaging/breaking it??
I’ve gotten as far as removing the horn pad and top plastic trim to the steering column but I’m finding that getting a thin wall 27mm deep socket on the steering wheel nut is an impossible task without breaking the plastic horn contact piece.
1st photo is the overall view of the piece I need out of my way to access the nut holding the wheel on.
2nd and 3rd photos show how ridiculous the obstacle is to getting a socket and breaker bar on the nut holding the wheel on.
Someone please tell me what steps I’m missing, I’m about ready to say **** the old wheel and take a crowbar to it since I’m removing to install an R-Sport wheel anyways. But obviously, I’d prefer not to trash the original.
File Type: jpg BB18AAC5-D1B9-4472-B12D-37174916C7F7.jpg (203.8 KB, 152 views)
File Type: jpg 3CC503F8-AC92-4481-85F8-E6C495F2BE29.jpg (207.1 KB, 156 views)
File Type: jpg 567E31F2-BADF-4B6D-A9D6-9816AE069210.jpg (201.0 KB, 153 views)
1993 945TI - 601 Red/Grey AW71-L - FOR SALE
1987 744GLE - 177 Grey/Oxblood M46 - FOR SALE
1984 242TI - 200 Blue Metallic/Black M46
1987 765TI - 200 Blue Metallic/Black M46
1987 745TI - 173 Red/Black Houndstooth M46
1992 745TI - 189 Polar White/Grey AW71-L
1966 122S - 67 White/Black M40 - SOLD
1983 242TI Evolution - 189 White/Blue M46 - SOLD
1986 764TI - 189 White/Oxblood AW71 - SOLD
TheVolbro is offline   Reply With Quote
Old 03-12-2022, 09:50 PM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
Looks like you peeled the cover off of the horn pad but didn’t remove the actual horn pad. The black plastic part covering the steering wheel nut needs to come off too (it should have come off with the horn pad cover). Give it a good yank and it will come off.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 03-12-2022, 09:52 PM   #3
The Librarian
That piece comes off. It takes a bit of effort to unsnap the 4 retainers, one at each spring/contact.
Old 03-12-2022, 11:56 PM   #4
TheVolbro
The Collector
TheVolbro's Avatar
I’ve got a bad feeling it’s going to break but that definitely seems like the only way. Will update with what happens!
Old 03-13-2022, 12:04 AM   #5
- Stock PSI Or Bust -
Never seen one come apart like that.
Too bad its a TURBO horn pad.
how psi stock cna sprout?
Old 03-13-2022, 04:04 AM   #6
2manyturbos
He worked hard to get that pad off. He has it straight now.
Old 03-13-2022, 09:39 AM   #7
OldCarNewTricks
OldCarNewTricks's Avatar
If you have one of those trim removal bone tools, you could pry up on each corner with it and avoid damage.
OldCarNewTricks is offline   Reply With Quote
Old 03-13-2022, 03:11 PM   #8
TheVolbro
The Collector
TheVolbro's Avatar
Fortunately the integrity of the pad itself is still good so I can swap it onto a new horn assembly if need be
Old 03-13-2022, 03:21 PM   #9
Mr. V
Mr. V's Avatar
I've broken and replaced the round clip-things that hold it to the wheel, so if you break something it shouldn't be the end of the world: just a PITA trying to source a replacement, as it often is anymore with old 'bricks going to the crusher.
Old 03-14-2022, 09:27 PM   #10
TheVolbro
The Collector
TheVolbro's Avatar
Update: got the horn mechanism off using a flat end crowbar and it did not break! There was some sort of adhesive residue like a glue that was applied to the round clip-things that hold it to the wheel. I guess factory really didn’t want it going anywhere.
Fortunately I didn’t need a wheel puller to get the wheel off the steering shaft, but I found I’m missing a piece or two for the R-Sport hub so I’ll be driving with vice grips in the meantime
Jk… I’ll be using one of the other Volvos in my fleet until I get the part I ordered from eBay
Old 03-15-2022, 02:24 AM   #11
MasterBlaster
MasterBlaster's Avatar
Probably looked something like this (just yours is torn in two)?
https://www.ebay.ca/itm/125165413980...oAAOSwbFRiFo5S
1990 740GL
539,000 km so far...
Old 03-15-2022, 03:01 AM   #12
Toybox
mostly lurking
Toybox's Avatar
[...] but I found I’m missing a piece or two for the R-Sport hub so I’ll be driving with vice grips in the meantime
I admit it, you got me. Damn near had a heart attack sitting right in my chair.
Old 05-19-2022, 02:04 PM   #13
TheVolbro
The Collector
TheVolbro's Avatar
Just realized I left this thread without a resolution so?
I was able to put the rubber ?Turbo? horn pad back together with the horn mechanism with nothing damaged. The steering original steering wheel is now in storage.
I think the NOS RSport steering wheel kit I acquired had the wrong wheel hub in it, which was the only part that didn?t look new. I ended up going with a Momo hub adapter from Ben at BNE Dynamics and I was finally able to mount the wheel and be its first driver.
File Type: jpg E0616593-1A60-4356-8049-6AC06FF3C85D.jpg (198.2 KB, 61 views)
Old 05-19-2022, 02:13 PM   #14
Old and boxy but good.
Looks great. Enjoy!
Old 05-19-2022, 06:08 PM   #15
philski o'flood
philski o'flood's Avatar
good looking wheel! never touch it with grubby hands ok
philski o'flood is offline   Reply With Quote
Old 05-19-2022, 06:39 PM   #16
The Librarian
Which hub came with the wheel? There were 3 different hubs for 240.
Old 05-19-2022, 06:58 PM   #17
2manyturbos
+1 OP, considering how you use the 242, get yourself some driving gloves.
Old 05-21-2022, 06:28 PM   #18
TheVolbro
The Collector
TheVolbro's Avatar
I?ll snap a couple pics later today. I suspect since the steering wheel has a 1983 date code that the hub either belongs to a different model than my 1984 240 or that the kit was missing some parts because it definitely wouldn?t install correctly and looked incomplete when mounted
Old 05-21-2022, 06:28 PM   #19
TheVolbro
The Collector
TheVolbro's Avatar
I?m looking into the driving gloves haha
Old 05-21-2022, 08:54 PM   #20
2 old for this
I see you have my same driving shoes.
