Old 09-25-2012, 01:18 PM   #51
Roger Berglund
i have found out that http://www.libertysgears.com/ do upgraded versions of the Tko 600 gearbox.
and i have mailed them and asked if it is posible to Shift at 9200 RPM. and it was no problems ;).
iam going for the FACE PLATED TKO 600 Gearbox ..
Roger Berglund is offline   Reply With Quote
Old 09-25-2012, 01:19 PM   #52
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
sorry for not responding to your question, but in truth I did not know.
Old 11-02-2012, 04:36 AM   #53
Roger Berglund
This is my crankcase breather!
i have cut off an distributor and i have make a Thread inside. hmpf my english if very bad but i hope the picture tells more than words
Old 11-02-2012, 09:48 PM   #54
cosbySweater
cosbySweater's Avatar
that is so fricken coooollllll can i visit you when i come to sweden next year and have one? all joking aside this is one of the few threads i follow
1995 Porsche 993
2013 VW Passat TDI
Old 11-14-2012, 02:03 PM   #55
Roger Berglund
I have lift out the engine , beacuse it is going to an Engine dyno . we think it might be possible to make about 500 HP and its is going to run E85. the pressure well..every thing about 1,5 Bars pressure to 2,5 bars pressure it depends about how much pressure we need to make to take out 500 hp. if it make 500 hp with 1,5 bars boost or lower. i still want to press the engine to the max , i will make and update of the engine testing very soon.
i know that the engine its self isnt very speciel but the intake manifold and exuast manifold is very potensial, there whers the secret hides .
The Engine Setup;
Stock 531 cylinderhead with the "yellow market valvesprings".
K-camshaft
Stock B230FB
1260 injectors
home made intake manifold
Ajden exusst manifold
Sävarturbo Wastegate.
Holset hx 40 super with 19# housing , T4 flens type
4" downpipe
Autronic sm4
Bosch motorsport spole wastedspark.
Old 11-15-2012, 01:43 PM   #56
Roger Berglund
Old 11-15-2012, 02:12 PM   #57
Finnish240
Finnish240's Avatar
Word -big- isn't enough when you are describe this engine. Everything is HUGE!!!!
Volvo 240 GL - not so low, but yes.... it is slow
Finnish240 is offline   Reply With Quote
Old 11-15-2012, 02:15 PM   #58
DNAsEqUeNcE
†John3:16
very nice manifold design.
Old 11-15-2012, 02:31 PM   #59
Old Iron
I Roll
Old Iron's Avatar
Sweet build.
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 11-18-2012, 04:13 PM   #60
Roger Berglund
423 Hp , 480 nm , 1,5 bars boost and on leadfree 98 octane fuel .
tomorrow we are going to use E85 and the boost target is 2 bar. and we think that i might be possible to make 500 hp! :D.
stay tuned!
Old 11-18-2012, 06:13 PM   #61
Roy 940
WOW! Nice numbers! Congrats!
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 11-18-2012, 06:53 PM   #62
Hodginsa
Always
Hodginsa's Avatar
No issues with the up flowing drain line? Sweet numbers on the 8v. I dream of those.
http://idlehandsproject.com - Keep me busy.
Hodginsa is offline   Reply With Quote
Old 11-18-2012, 07:09 PM   #63
pwschuh
Rolling...
Chassis dyno or engine dyno?
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 11-18-2012, 10:34 PM   #64
diponyou
diponyou's Avatar
engine dyno
Brandon B.
1993 240+T ms2v3, 96#s, e85, T5
1984 242ti Hi-Comp b23 N/A, m46. Work in progress
93's Build Threadhttp://forums.turbobricks.com/showthread.php?t=264885
84 242 Hi-Comp N/A Build Thread
http://forums.turbobricks.com/showthread.php?t=290023
diponyou is offline   Reply With Quote
Old 11-19-2012, 03:40 PM   #65
Roger Berglund
502hk @ 2.0bar/6600rpm (566nm with rich mixture and very low "tändning" ? spark adjustment was very low..hmpf i suck at enligsht. 17 degres or less )
we didnt have any boost control , we are cutting the NM with the spark adjustment..lower.. and rich mixture.
Old 11-19-2012, 03:52 PM   #66
2fast242gt
Do you have a cobalt?
Very nice!!
1983 242dl
*6.0 lq4 swaped* Build thread
Old 11-19-2012, 07:04 PM   #67
DNAsEqUeNcE
†John3:16
I see. nice numbers.
Old 11-24-2012, 07:10 AM   #68
Roger Berglund
Old 11-24-2012, 10:25 AM   #69
ahawks9er
Prodigal Swede
ahawks9er's Avatar
Nice graphs. New numbers this time? Tuning changes?
1983 244ti - Gone, but not forgotten
1992 Miata - Came back to me after 6 Years
1997 Lincoln Town Car - Thanks, Gramps.
ahawks9er is offline   Reply With Quote
Old 11-24-2012, 10:33 AM   #70
DNAsEqUeNcE
†John3:16
you had enough for 500wheel on 1200cc injectors w/ e85!
Old 11-24-2012, 10:44 AM   #71
J2_
J2_'s Avatar
K cam or VX3 cam? They are different...
I think you will get -way- more power with a better cam..
Still.. Very nice!!!!
J2_ is offline   Reply With Quote
Old 11-24-2012, 02:34 PM   #72
Roger Berglund
its a K camshaft i dont know why jens had wrihte ( vx3 )
the worst part is with 500 hp on e85 we are using 3,5 pressure on the BTR. is we had use 3 bar on the fuel pressure we didnt have fuel enogh for that kind of hourse power.
and yeah i have some plans to change camshaft and putt in some h profil rods in the future.
we hade 90% duty cycle on 2 bars boost on E85 . with 1260 lucas injectors and using 3,5 ground pressure to the fuel line.
Old 11-28-2012, 11:00 AM   #73
Roger Berglund
https://www.youtube.com/watch?v=k0yKiK10XNQ
https://www.youtube.com/watch?v=QFDN...hannel&list=UL
Old 11-28-2012, 05:02 PM   #74
Roger Berglund
i have bought some H-rods from motornord.se . so iam going to shift rods and iam also going to give some love to the cylinderhead. i got better springs already and titan retainers.
iam still going to run the K-camshaft .
i might be passible to rev 8500 with the new valve springs . iam going to install an boost valve to controll the boost at rpm. higher rpm = higher boost , so iam gooing to make the curve like you harder you rev it desto meaner machine :D. and the NM curve will raise all to the top om 8500 rpm .
Old 12-01-2012, 06:06 PM   #75
Roger Berglund
aiming for 8500 revs with the K-camshaft ;).
