Old 03-30-2019, 07:56 PM   #1
Bready
board deviant
Bready's Avatar
Default Rear view mirror NOW WITH THRILLING UPDATE!
Is there a way to tighten the ball socket on the rear view mirror?
Thanks
Originally Posted by Pennybridge Pioneer View Post
Just because you didn't experience something growing up doesn't mean other people didn't. Case in point: I can't remember ever being a total moron, but that doesn't mean you aren't one.
A society that treats this much Black death at the hands of the state as collateral damage in a just war on crime has no decorum to project. That society is savage. - Charles M. Blow
Kalazdar - (3/23/83 to 5/12/03)
MUST READ!!! https://cleantechnica.com/2017/04/24...-adds-screwed/
Bready is offline   Reply With Quote
Old 03-31-2019, 06:26 PM   #2
2 old for this
J b weld = adjust it once? Rough up the ball ? Take a sharp punch and puts some digits in the can ? Get a different mirror?
Old 04-01-2019, 04:14 PM   #3
Bready
board deviant
Bready's Avatar
Anybody else...
Old 04-01-2019, 07:10 PM   #4
Bready
board deviant
Bready's Avatar
Well not really thrilling.
Noticed that the "ring" that I'm assuming provides tension on the ball socket came off and is just loosely hanging on the mirror arm. Anyone have any luck getting that thing back on? I screwed around with it for a bit but had little to no success.
Old 04-01-2019, 08:58 PM   #5
nel621
Once the ball comes out of the socket it will always remain loose. I took one apart once. I wanted to replace the mirror with one from a different car that had lights on the bottom. Thought that would be a neat upgrade. It always flopped down. Finally got another one with the lights and modded the whole thing to fit. Used the windshield bracket that you glue in place and snaked the wires behind the trim. Sorry I can't help you . Just my own experiences.
Old 04-02-2019, 03:18 AM   #6
Bready
board deviant
Bready's Avatar
All good appreciate both of your inputs.
The "ring" puts pressure on the plastic that surrounds the ball - hence creating tension. I think I'm just going to try to put a tie wrap there instead of the ring (doesn't seem to be any practical way to reattach that) and tighten it with a tie wrap gun to see if I can get the same result.
Old 04-02-2019, 07:22 AM   #7
Shifted
Shifted's Avatar
I'm totally shooting in the dark here, but could a spring be incorporated into the mechanism to restore stability? Alternatively, some adhesive foam tape/similar?
People just aren't smart.
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
Originally Posted by miguels244 View Post
Yeah...buy cheap crap and watch your kid's jobs evaporate.
"The table is tilted folks, the game is rigged. And nobody seems to notice, nobody seems to care..." -- George Carlin
Shifted is online now   Reply With Quote
Old 04-02-2019, 10:37 AM   #8
Beep beep zip tang
Make a shim from plastic, wood, match sticks, aluminum foil?
Old 04-02-2019, 11:57 AM   #9
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Put a condom on it and put it back in? Or the finger from a nitrite glove would work too I suppose....
Old 04-02-2019, 01:06 PM   #10
nel621
Once the ball comes out of the socket it is very difficult to get tension back on it. I guess you can try to "peen" the edge all around.
Old 04-02-2019, 02:18 PM   #11
Bready
board deviant
Bready's Avatar
Thought about that - (and was actually recommended earlier) probably the second plan if the tie-wrap doesn't accomplish what I'm trying to do.
Old 04-02-2019, 02:20 PM   #12
Bready
board deviant
Bready's Avatar
I don't want to take it off, it's still in the socket, not sure if it can be put back on without damaging the mirror and then all hell breaks loose since it's an integrated part of the security system.
Old 04-02-2019, 02:20 PM   #13
Bready
board deviant
Bready's Avatar
My exact concern.
Old 04-03-2019, 12:13 AM   #14
swedefiend
swedefiend's Avatar
My exact concern.
I asked for pics. You never provided.
Are you sure you don't place the clip and then press the ball into the socket? This is what I would suspect but cannot confirm as I have never had to troubleshoot a rear-view mirror.
Old 04-03-2019, 03:45 PM   #15
Bready
board deviant
Bready's Avatar
Pics are coming.
Old 04-03-2019, 09:11 PM   #16
JohnLane
Well that was riveting!
