Old 06-21-2019, 11:10 AM   #1
swedefiend
swedefiend's Avatar
Default Incredible fail. Please help.
First gen s40.
Split engine and transmission when I swapped engine.
Took off crank position sensor bracket. Forgot to replace it. Now engine is in the car, half way reinstalled.
Won't be able to get the bracket installed without partially removing the transmission.
How far back can I move it before the torque converter unseats?
I really should crush this ****ing car. What a CF
Old 06-21-2019, 11:14 AM   #2
Jack
junkman
Jack's Avatar
Originally Posted by swedefiend View Post
First gen s40.
/thread
I love you even more Jack.
Old 06-21-2019, 11:18 AM   #3
swedefiend
swedefiend's Avatar
/thread
I am again eternally indebted to your illuminating insight.
/s
Old 06-21-2019, 11:21 AM   #4
/s
Last time I checked they were disposable cars.
Did I miss something in the interim?
how psi stock cna sprout?
Old 06-21-2019, 11:26 AM   #5
Jack
junkman
Jack's Avatar
/s
here is is... probably pretty damn far
Old 06-21-2019, 01:39 PM   #6
alschnertz
Enough already!
alschnertz's Avatar
For clarification, you bolted the converter to the flex plate prior to installing the transmission?
Why not unbolt the torque converter and let it slide out with the transmission?
That's how I remember doing it on my '01.
Old 06-21-2019, 05:22 PM   #7
swedefiend
swedefiend's Avatar
The friend I had helping me suggested loctite for the converter bolts
So, it will either be repaired by sliding the transmission back until I can place the bracket... Or, I will actually crush it
Old 06-21-2019, 05:43 PM   #8
GTJordan
Been here for too long
GTJordan's Avatar
It only goes about 1cm before the torque converter will unseat.
Undo the torque converter. Loctite is never permanent.
80 242- 2.5L 16V, NIW intake/exhaust, GT3076, T5 w/ 2.95 gearset, Porsche brakes, Gaz short coilovers/shocks and Kaplenkhe suspension, Trutrack.
Old 06-21-2019, 06:22 PM   #9
alschnertz
Enough already!
alschnertz's Avatar
Agreed.
Just make sure your wrench fits properly and I bet it will unscrew.
In this case, I believe it is a torx fitting.
FWIW, I didn't Loctite anything and it's lasted 60K miles since I changed the transmission.
I have no reason to doubt this engine/transmission combo will last at least 300,000 miles. 235,000 now.
Though the body on this '01 may not survive another 5-years of CT DOT Magnesium Chloride winters. Even though they promise that "it's not that MgCl brine is more corrosive, you just have to wash your car more often".
Yea, DOT really said that.
Old 06-21-2019, 07:39 PM   #10
swedefiend
swedefiend's Avatar
Well, I left the converter connected and the long bell housing bolts still threaded in with 1/2" or so of shank showing.
The transmission fell back on it's own. I inserted the wayward bolt and then tightened everything back up.
Will the pump shear? Only time will tell
(Really starting to hate this car anyway)
Old 06-21-2019, 07:52 PM   #11
alschnertz
Enough already!
alschnertz's Avatar
Been meh on mine since I received it from my daughter 3 years ago.
It really has been a very dependable ride over the years.
I wouldn't call it fun, but more like a very good appliance.
Old 06-22-2019, 04:31 PM   #12
jnvolvo
Sounds like operator error, not automobile error on this one man.
You think you hate the car? Think what it's like having a guy who forgets steps completely working on you! Thank god you're not a cardiac surgeon. ;)
"****. Nurse... this was a mechanical valve install. We've already got the chest half way closed up, and I Just found the mechanical valve over here on a tray. Do we need to open him back up? How far?"
jnvolvo is offline   Reply With Quote
Old 06-22-2019, 05:36 PM   #13
apachechef
Burnt Sierra Madre
Op Note:
Patient was prepped and draped, initiation of anesthesia uneventful.
The chest cavity was opened, the heart stopped, and extracorporeal heart lung machine activated. Pt was deemed not a valve replacement candidate.
spontaneous cardiac rythym reestablished, surgical wound closed.
pt recovering nicely
PAYME
Dammit, Lummert.
Old 06-22-2019, 06:46 PM   #14
jnvolvo
Originally Posted by apachechef View Post
op note:
Spontaneous cardiac rythym reestablished, surgical wound closed.
Pt recovering nicely
payme
hahahahahahaha
Old 06-22-2019, 06:49 PM   #15
jnvolvo
