Old 03-30-2020, 05:59 AM   #1
Solo
Default My Catalytic Converter was just stolen.
Someone has taken the liberty to lighten my vehicle just abit while I was at work earlier yesterday afternoon. I need some help to source an original catalytic converter and front pipe for a '94 NA 945 with egr. I've only been able to find the O2 sensor for it. I'm not even sure what an original catalytic converter and its front pipe will cost. The catalytic converter that was taken was the catalytic converter that came with car from the assembly line. I'd like to put back an original catalytic converter back onto this vehicle. As always thank you for any help and/or information that you can provide.
P.S. Just a side note. In the last few hours since this happened. I've had to talk to and ask people for help with this sudden issue. I'm so sad that this part is now missing from my Volvo. I'm still tearing up a bit whenever I have to repeat this phrase to other people. I try hard to take good care of my Volvo. In a few hours I'll be running to/calling a few dealerships to see if they can offer any assistance with this issue, but I understand that with this pandemic going on that I'll receive little to no help at all and my car will run and sound horrid for the foreseeable future. I just hope nothing will be damaged by it missing its cat and O2 sensor. I'll probably receive a few tickets behind this. I just went through a lot just to be able to get my Volvo back on the road four months ago (after four years of it sitting in a shop) and now this. I just wish that I'd caught the person that did this to my Volvo......but I was at work at the time it happened.....I apologize for this side rant.
Solo is offline   Reply With Quote
Old 03-30-2020, 06:29 AM   #2
Beep beep zip tang
https://www.partsgeek.com/gbproducts...EaAg6cEALw_wcB
You can check with a dealer but they are going stick it in and break it off
Old 03-30-2020, 07:30 AM   #3
Dicktater
Cretin
Dicktater's Avatar
Do you live in an area that has smog checks? The factory cat would be lots of $$$$$
**** off loser. I will **** you up. I back up the **** I talk. I don't back down because I am not wrong. You want some? Bring it mother****er.
Originally Posted by CaliMeatWagon View Post
I hope your treehouse gets cancer
I buy a few when foodstamps get here because I have an investment strategy.....
Originally Posted by volvo740b234/531 View Post
I smoke my weed and dream of an awesome life
Feedback >http://forums.turbobricks.com/showthread.php?t=197700
Dicktater is offline   Reply With Quote
Old 03-30-2020, 09:17 AM   #4
Otto Mattik
board member
Otto Mattik's Avatar
Curious what state, if you have CA cat laws or whatnot ?
Here is link at rock auto they say one left $105.79 p.n. 48471 w/egr (no idea on quality ?)
https://www.rockauto.com/en/moreinfo...sn=379&jsn=379
https://www.rockauto.com/en/catalog/...ion,pipe,10038
Old 03-30-2020, 09:47 AM   #5
kyote
Living The Dream
kyote's Avatar
Muffler shop for a Universal, won't happen again.
Old 03-30-2020, 10:35 AM   #6
JohnMc
JohnMc's Avatar
A little casual clicking around leads me to believe that Volvo no longer sells the OEM original cats. I just had a bit of morbid curiosity about how much that would cost.
About the best you can do is use an aftermarket cat and a good replacement O2 sensor. The O2 sensor does have a large influence on how your car runs, the cat, as long as it doesn't clog, has no influence.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 03-30-2020, 12:50 PM   #7
There are a couple of things you need to figure out as the guys are pointing out. You need to determine whether you need a CA spec cat or if it is 49 state. Then you need to determine what engine management system your car has. Either Rex/Regina system or Bosch LH2.4. The O2 sensor is different for each system and if you get the wrong one your car won't run correctly.
Old 03-30-2020, 04:52 PM   #8
Khrrck
Professional Amateur
Here is link at rock auto they say one left $105.79 p.n. 48471 w/egr (no idea on quality)
I have a new 240 cat from RockAuto/Bosal sitting in my living room right now. Construction is solid and the grid looks good. Cannot comment on the accuracy of the fit as I ended up re-using the old cat (matrix was still clear and it passed smog no problem afterwards). It's one piece instead of having crimped seams which is nice. Touch of surface rust at the weld-on flanges but nothing surprising. Could probably put high temp exhaust paint on the outside if you were concerned.
'87 240 budget wagon.
Old 03-30-2020, 09:38 PM   #9
2 old for this
Did you get law enforcement involved? Comprehensive insurance? 200 pound Rottweiler?
Old 03-30-2020, 11:32 PM   #10
Solo
Originally Posted by VB242 View Post
....You can check with a dealer but they are going stick it in and break it off
I know.
Originally Posted by Dicktater View Post
....Do you live in an area that has smog checks? The factory cat would be lots of $$$$$
Yes. It will cost much more if I can even find one in new old stock condition. Currently trying to contact all of the dealerships in order to try to track down another cat. As I was told by one parts counter salesperson. "Volvo doesn't keep track of discontinued parts. So you'll have to contact each dealership and ask them if they still have that part in their parts room."
This I already know, but is it a crime to have your Volvo be as quiet as it can be?
.....The O2 sensor does have a large influence on how your car runs, the cat, as long as it doesn't clog, has no influence.
The original cat was between $800-$1800US, back when they were available from the dealership.
Originally Posted by dl242gt View Post
.....The O2 sensor is different for each system and if you get the wrong one your car won't run correctly.
The car is not only LH 2.4 it also has Pulse-Air and Egr. I'm trying to decide if 9135793 or 9135795 is the correct O2 sensor for it. I'm thinking that it needs 9135795. The front pipe is proving to be a bit more troublesome to procure. If I cannot find another oem factory cat, then I'd want to install a CARB-compliant cat, but I cannot find the correct pictures and part numbers for the direct fit models.
Originally Posted by Khrrck View Post
...Could probably put high temp exhaust paint on the outside if you were concerned.
What is the part number on that Bosal cat?
1. No.
2. None.
3. ....Wha...What?
Old 03-31-2020, 12:18 AM   #11
bobxyz
bobxyz's Avatar
Where are you? Maybe someone can recommend a good independent muffler shop.
You'll need a new CAT, maybe CA certified, and some replacement pipes. A good local shop can do a original quality level installation. Around here, there's a few independents that do really nice work for not much $$$. They take pride in their work and keep the overhead low.
Best wishes, and sorry that scum has temporarily invaded your happy Volvo space.
bobxyz is online now   Reply With Quote
Old 03-31-2020, 12:30 AM   #12
Toybox
mostly lurking
Toybox's Avatar
Yep, pretty loud coming out of the manifold with no pipe. I'll bet that was a surprise when you fired it up! Sorry to hear someone would do that.
If it's a 94 then it probably had just the single O2 sensor? I'm guessing the computer will default to limp mode but someone else can chime in for the details. For sure, it'll be hard for the computer to maintain any sensible air/fuel ratio... if lean it can detonate, and if rich it can wash excess fuel down the cylinder walls.
Not sure how much of this you already know, or you probably wouldn't be asking about whether anything "can be damaged." I surely wouldn't run like that any longer than I had to.
Sadly, the 200-lb dog wouldn't have helped unless there was a way for him to get out of the car during the moment of need.
Old 03-31-2020, 01:31 AM   #13
Otto Mattik
board member
Did you see the link I posted for rock auto ?
The 1st link was an illustration and 2nd link shows the header pipe price/order link
Part Number 48471 AP Emissions w/ E.G.R. (Only 1 Remaining)
Old 03-31-2020, 03:28 AM   #14
Solo
Originally Posted by bobxyz View Post
.....Best wishes, and sorry that scum has temporarily invaded your happy Volvo space.
I'll just need a direct replacement cat since I cannot find the original one (1389966), a front pipe (9135305), and an O2 sensor (It's either 9135793 or 9135795. I think that it's going to be 9135795 {engine code is 83}) I may just change out all of the under carriage exhaust system components. I won't trust a shop that wants to weld anything together on my Volvo's exhaust system. I've been to alot of the local shops around here and that is the first thing that they all want to do to your exhaust system. I remember when I had an exhaust leak in my front header pipe (I already knew where the leak was coming from because I'd already smoked the car's exhaust myself before hand) about 10-12 years back. I took it around to about 10-15 of the local shops and they all told me that I had leaks all over the place and that they'd need to weld everything together to get rid of all the leaks that they'd found. A few of them also stated that the leaks that I had were all in bad spots so they'd have to charge me extra to do the work. Since I couldn't find a honest shop, the next morning I went to the dealer, ordered another front pipe, and installed it myself that afternoon.
Yes, It is really loud without it's cat in place. I really appreciate this information. I'm not planning to drive it anymore than the 30-45 mins it took for me to get in back in a yard. Even when I had to do that I did it in two stages with a 3-4 hour rest period in-between. The animal would have been hurt by this individual also in addition to the missing cat.
Yes I'd seen and checked out the links that you'd posted, but there wasn't any actual part pictures of that front pipe only an illustration of the part. Also in its description there was no mention if its fittment was for 944 or 945.
Old 03-31-2020, 04:18 AM   #15
Otto Mattik
board member
Yeah illustration isn't much to go on if the front pipes are different for a wagon, I didn't know that detail on the 900 series. I'm wondering if cross referencing the P.N., is an option ?
Sorry to hear about your car, hope you figure it out. Yeah looked around a bit for that pipe, I assume your engine #83 is B230FD(not sure what D stands for). I would suggest contacting Volu parts, Atlanta, if they don't have a new part they sell used OE parts too.
Old 03-31-2020, 06:29 AM   #16
Beep beep zip tang
Why would the front pipes be different? I've never seen more postulating over an exhaust system before.
https://www.fcpeuro.com/Volvo-parts/...&b=6&d=52&v=11
Old 03-31-2020, 10:42 AM   #17
white855T
Skandix has a genuine Volvo cat. https://www.skandix.de/en/spare-part...erter/1002614/
Old 03-31-2020, 11:49 AM   #18
JohnMc
JohnMc's Avatar
Are the rear pipes different? I mostly know 240's - and there's no difference between wagon and sedan from front to end on the exhaust system.
Old 03-31-2020, 12:22 PM   #19
For the o2 sensor. Save money and buy a three wire universal one at a local autozone or pep boys, or advance auto. It comes with the connectors so you can attach it to the original wiring harness on the car.
Old 03-31-2020, 01:19 PM   #20
oldnfast
I’ve replaced the header pipe on various 7/9 cars and have never seen a reference for wagon to sedan differences. Not even the rest of the exhaust now that I think about it
Also besides the oem cat costing $$$$ wouldn’t the thieves just steal it again?
I’d guess even those scumbag ****ers know the generic replacements aren’t worth anything
oldnfast is offline   Reply With Quote
Old 03-31-2020, 04:11 PM   #21
lummert
lummert's Avatar
Bosal should have direct fit.
Old 03-31-2020, 06:09 PM   #22
colgate41
colgate41's Avatar
FCP Euro or eEuro parts should have what you need.
1991 744 Turbo. Last Volvo left.
colgate41 is offline   Reply With Quote
Old 04-01-2020, 05:48 AM   #23
Otto Mattik
board member
^^ looks like FCP beat rock auto's price
Old 04-01-2020, 08:26 AM   #24
swedefiend
swedefiend's Avatar
Seriously. Someone find this guy a local shop that he isn't wary of.
The. Entire. Exhaust. On my 83 was welded together by strangers
It's been sitting for over ten years but I bet that my 275lb ass could still swing from it.
Sorry to hear about your run-in with dirtbag thieves. I can *almost* feel your pain.
Old 04-01-2020, 08:39 PM   #25
2 old for this
Cat theft is more common than most think. Craigs list is full of “buyers”.
