Ayy!
I'm trying to figure out what is wrong and feel quite stuck on this one.
Car is a 945 GLE -91 B234F (auto cambelt tensioner) with an M46.
I replaced the head gasket (0.1mm of head removed) because of tiny amounts of oil ending up in the expansion tank.
All 4 cylinders have compression, just around 12.8-13 bar.
I've cycled the spark plugs between all 4 cylinders, yet cyl 3 wont run smooth. Safe to say plugs are OK in my opinion.
Rotor, distributor and plug wires are all new. All plugs have a spark.
Cams+crank are all zero'd as you can see in the short film I've attached. The balance belt was removed years ago.
No fault-readings according to the fault-code box
Fuel injectors are all clicking.
Film:
https://www.youtube.com/watch?v=vLx0Kz-ziOU
As you can see she starts up and runs great for about 1 second. Then she dips down to the rough idle where I can't decide if one cylinder is out or just idling really bad. If I give her some gas she smoothes out. Pulling cyl 3's spark plug wire won't change anything, however when pulling the injector cable, you can hear that RPMs dip and engine starts shaking even more (that's where my hesitation whether no 3 is running or not comes from). Plugging it back will rise the idle to normal for 1 second, then back down to the rough.
Oh, and I realised that there's one cable not plugged in under the intake manifold. Is is supposed to attach somewhere? The 3 sensors all are plugged in, and the idle air controller has got its cable. Maybe it's just an extra one that has always been sitting there without me noticing??
Pic:
https://i.imgur.com/yDoyGqr.jpg
Thank you in advance guys!
Film:
Pic:
