Old 06-10-2021, 04:37 PM   #1
Terry1941
Default 1984 245 Wagon Engine Stall
My daughter was driving the Volvo from her friends house in Renton back to Tacoma and while driving about 45 mph heading towards the freeway the engine stalled. She was able to coast into a nearby business parking lot. When I arrived to tow the car back home I noted that the key worked, the lights came on, the engine would turn over, there was gas and oil where it should be. I now have to troubleshoot to see just what might have happened, fix it, and get her back on the road again. Any suggestions on where to start?
Terry1941 is offline   Reply With Quote
Old 06-10-2021, 05:03 PM   #2
TestPoint
TestPoint's Avatar
Just a drop dead is more likely electrical rather than fuel. I would expect a fuel problem to cough and sputter a moment before a complete stop.
My first test in this situation would always be a shot of starter fluid. If it runs on starter fluid it is a fuel problem. No run, electrical.
Fuses, obvious electrical connections. Crank position sensor wires.
Ford V8 Conversion Manual -
Old 06-10-2021, 05:23 PM   #3
Terry1941
Thanks, will it it a try.
Old 06-10-2021, 05:52 PM   #4
Khrrck
Professional Amateur
What version of engine management is the car running? Probably LH 2.1?
If it mysteriously starts running again, I always have gotten good mileage out of wiggling all electrical connectors and seeing if one of them makes it die again. Then you pull that apart, shoot with contact cleaner and apply dielectric grease to reduce future corrosion.
'87 240 budget wagon.
Old 06-10-2021, 06:23 PM   #5
Terry1941
Not really sure on the engine management other than it is fuel injected. I tried the starter fluid and nothing happened. I checked what fuses there are, could find no main or engine fuse, and they are all good. I played with the various different wires in the engine compartment but nothing there. One thing that was strange was that last October we put a new Interstate battery in and repainted the tray with corrosion resistant zinc oxide and it now has a real thick silver/white crystal like residue on the tray. I have seen plenty of battery acid residue but this is uniquely different I am sure it is unrelated though.
Old 06-10-2021, 06:38 PM   #6
Terry1941
I would post some pictures if it were not so complicated to do so.
Old 06-10-2021, 07:30 PM   #7
TestPoint
TestPoint's Avatar
Pictures not complicated, just not hosted on this forum.
I am trapped onto PhotoBucket but it is not a favorite anymore. Post on a picture hosting site, copy the link address, click on the mountains icon and paste. There you go.
Old 06-10-2021, 08:53 PM   #8
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
A 1984 non-turbo 240 would have LH 2.0.
Anyway, it sounds like it might be an ignition issue if the car cranks with no sign of starting. If you hear the starter solenoid engage, but no cranking, check the battery terminals, especially if they are the aftermarket style with the clamp that goes over the battery cable with two bolts.
My family had an '84 245GL that, every two years, would develop corrosion on the positive battery cable. Sometimes it would stall, then restart almost immediately, other times, the whole electrical system would go dead, either coming back 30 seconds later, or remaining dead until the terminal connections were cleaned up. Car continued to do this until the battery was replaced with one that didn't belch out acid. Seems the factory translucent case batteries weren't very well-sealed. It's possible that the Interstate battery in your 245 has the same issue. Kinda rare on an Interstate battery, but it can happen.
@john242ti on IG
Old 06-10-2021, 09:16 PM   #9
daniels740
On the topic of battery terminals, my 740 would get the worst corrosion on the positive terminal. I went through two or 3 replacement terminals before finding a good solution. What I did and suggest you do is use the following two products to first clean and neutralize the acid/corrosion and then prevent future corrosion.
To clean and neutralize the acid: https://www.walmart.com/ip/NOCO-Remo...B&gclsrc=aw.ds
To stop any further corrosion: https://www.walmart.com/ip/NOCO-NCP2...t-Kit/16213366
That's under a $10 total with tax, to get the job done right the first time. I've used multiple greases including dielectric and this is the only solution I've tried that will keep your terminals healthy and making good contact.
Anyway, if starter fluid hasn't worked, you definitely have a spark or timing issue. Timing belts usually don't fail with the engine running, but check that your camshaft is moving (see if there is movement under the oil cap when cranking). If all's good concerning that, then count on becoming good with a multimeter if you aren't already, thankfully these cars aren't too complicated
daniels740 is offline   Reply With Quote
Old 06-10-2021, 10:19 PM   #10
Terry1941
The battery terminals are clean and in good shape, which is odd with the amount of corrosion in the tray. The battery sides are clean with no signs of residue (just replaced a Les Schwab battery on our 2002 forester and it was heavily creamed with green goo. Checked the fluid in the battery and it was normal. The valves move when the engine turns over. Not much experience with troubleshooting electrical engine components. It does have some kind of electronic box under the washer reservoir which I assume must be the brain for the system. It also has a map sensor (cleaned that about 6 months ago).
When we first purchased the car last year we had it looked at by a local Volvo repair mechanic who said that 1984 was the worst year for Volvo and the ignition system was most problematic. Don't really now what might be so unique about this year, could possibly be what we are experiencing, or could be just his opinion. Any thoughts?
Old 06-10-2021, 10:25 PM   #11
Terry1941
will still get those Walmart battery cleaning products and try them out any. The problem could be hidden.
We replaced the rear in tank fuel pump last year. The main pump has had an annoying buzz. Could this be a culprit? She said the car had a noticeable but very brief (she said it was hard to describe) lurch before it went dead stick and she realized there was nothing there.
Old 06-10-2021, 11:00 PM   #12
daniels740
If it was the pump, the engine would probably have started off the starter fluid. Where did you spray the starter fluid into? I found that sticking the little straw into the intake hose right before the throttle body and spraying a small steady stream while cranking the engine will get it to fire and in fact run quite nicely if fuel delivery is the issue. I actually ran my 740 on MAF sensor cleaner, lol.
Old 06-10-2021, 11:25 PM   #13
Terry1941
The map senor on the air cleaner side. Probably should try the other end at the throttle body.
Old 06-11-2021, 12:42 AM   #14
djshimon
djshimon's Avatar
How's that timing belt looking/sounding?
Self driving 240T
djshimon is offline   Reply With Quote
Old 06-11-2021, 01:12 PM   #15
The Librarian
Which distributor do you have? '84 should have the brown cap Bosch distributor instead of the white cap Chrysler one.
Have you checked for spark? Remove the coil wire from the distributor and place the end within ¼" of a grounded part of the chassis. One of the studs for the strut mount is a good location. While watching for spark have a helper try to start the engine. If you don't have a helper you can activate the starter from the test lead under the hood with a jumper wire. Just be sure the transmission is in park (auto) or neutral (manual) and the key is in the run position.
The starter test lead is near the dipstick.
If there's no spark go through the diagnostic tree to determine the fault.
The wires for the alternator and ignition are run behind and under the crank pulley. If the retainers are broken the wires can contact the pulley and rub through. They're also susceptible to degradation from oil leaking from the crank seal.
