Old 06-25-2021, 01:08 PM   #1
cookieboy
cookieboy's Avatar
Default Cam gear alternatives for '93 240 ?
Hi guys, I recently rejoined the Volvo famiy after I got my '90 240 back after a family member that I had given it to years ago had left it abandoned at his dad's driveway. But now I'm hopefully going to be inquiring about a '93 240 for my daughter and we're interested in getting either a B cam or VX3, but since the cam gear from IPD only fits '92 and older, are there any other alternatives or is leaving the cam timed straight up our only option and if so, would it still be any improvement over the M ? Thanks in advance !
1990 244 DL, (Given to stepson 3-2-13) (Reclaimed 7-23-19)
cookieboy is offline   Reply With Quote
Old 06-25-2021, 01:27 PM   #2
The Librarian
IPD has an adjustable round tooth gear.
https://www.ipdusa.com/products/2164...6842032-140129
STS also has them and they're on sale right now.
https://www.stsmachininginc.com/coll...o-b21-b23-b230
Old 06-25-2021, 01:30 PM   #3
cookieboy
cookieboy's Avatar
Great, thank you so much !!!
Old 06-25-2021, 01:39 PM   #4
Tonyte619
The STS one's are really nice. I like mine alot!
Tonyte619 is offline   Reply With Quote
Old 06-25-2021, 02:13 PM   #5
spock345
spock345's Avatar
The STS ones are really well made. Also I wouldn't be surprised if the IPD gears are made by STS.
1998 S70, grandma-mobile
Old 06-26-2021, 10:18 PM   #6
dalek
Benchracer Tribe
dalek's Avatar
They also make flywheels that remind me of JohnV's
Feedback!
Old 06-26-2021, 10:44 PM   #7
spock345
spock345's Avatar
I had one of those flywheels. A big improvement over the dog dish for LH 2.4 cars. Car is a bit easier to stall, but so much livelier.
Old 06-27-2021, 02:07 AM   #8
cookieboy
cookieboy's Avatar
Thanks again. On another note, what would be your recommended degree of advancement for an automatic equipped b230f if we go with the B or VX3? Or even a T cam for that matter?
Old 06-27-2021, 10:25 AM   #9
spock345
spock345's Avatar
I probably wouldn't advance a T cam. It has a good power band for torque with an automatic already.
Maybe try 2-4 degrees and then go from there for the B or VX3 cams.
Old 06-27-2021, 01:16 PM   #10
VX3 cam already has 3 deg of advance built into it. I'd start with all cams "straight up" and then try "1" marking on the cam gear either way.
The cam gears are all degreed with respect to the cam, not the crank. So 1deg on the cam is 2deg at the crank. So if someone is setting up a cam to be 3deg adv using the timing marks on the gear, it's actually at 6deg adv and probably making everything worse.
Old 07-07-2021, 06:12 PM   #11
cookieboy
cookieboy's Avatar
Thanks so much guys !
Old 07-30-2021, 03:19 AM   #12
klr142
Turbo, what?
klr142's Avatar
For a stock, automatic equipped car:
T cam, run it with tight clearances(.013"ish) and leave it straight up or even retard it 2-4 degrees indicated on the cam gear for maybe more high end pull(still hardly any, but still good torque).
B cam, run it straight up or advanced 2 degrees with near stock clearances(.016"ish) to maintain a reasonable idle quality.
VX3 cam, as mentioned it's already advanced a bit but I'd run it straight up or maybe even advanced a smidge more with .013-.016" clearances.
Putting a VX3 in my 1987 244 auto made it feel a little doggy after having the T cam in there retarded a couple degrees and with the clearances tighter. I don't know if it was slower, but I do know the T cam was at least faster than the M cam similarly setup in that car at the drag strip.
Old 08-01-2021, 02:52 AM   #13
cookieboy
cookieboy's Avatar
Thanks Kyle ! At the suggestions of the guys on here, I recently got a couple of cam gears from STS for myself and my daughter's newly acquired '91 245 w/AW70 (Thanks 122Power)which will hopefully be getting the T cam installed in the near future. So with the timing retarded 2-4 degrees, it sounds like maybe the car has more grunt than timed straight up?
Old 08-01-2021, 07:26 AM   #14
Janspeed
retarding a cam = shifting the torque/power curve up in the rev range
advancing a cam = shifting the torque/power curve down the rev range.
so, it's a question of where you want the torque to come in strong. Peak power is kind of mute in a daily driver anyway. Being zippy off the line and responsive when overtaking, that is useful.
Old 08-01-2021, 10:58 AM   #15
Jeh
Smorgasbord of Excellence
Jeh's Avatar
THIS...
When I first started working on my car before the +T advancing the the cam timing helped things. While the fancy IPD cam gears are nice, the creative man's way is to do it yourself with the stock gear.
6 degrees IIRC my math correctly was just shy of 1/2 a tooth so in my case I just rotated the gear 180 - 1/2 tooth and drilled a new hole and called it a day. You could get a timing gear/distro gear from an older 240 but even after the plus T I never felt the need to change it.
Originally Posted by RedFridge
That's why I love this place. Truly an information warehouse.
Originally Posted by kyle242gt
I post not for information, but for ignorant entertainment.
Originally Posted by Golgothan
Let's not forget, not many people on here set their car on fire with an oily rag, so glass houses and what not.
1994 Jaguar XJ6
Jeh is offline   Reply With Quote
Old 08-01-2021, 01:32 PM   #16
cookieboy
cookieboy's Avatar
Thanks so much !!
Old 08-01-2021, 06:52 PM   #17
klr142
Turbo, what?
klr142's Avatar
This. The T cam is so tiny and makes “so much” torque, I wanted to widen its usable powerband to help with passing power when the transmission drops down a gear, and just for more peak power. Hence the retardation.
