Inside_the_box
- Jan 29, 2014
- Falls Church, Va
Well I think I might have killed my engine. A little background, the car is a stock 76 242 that has been sitting for 7 years. I replaced the gas tank and both fuel pumps and got the engine running and idling on its own last week. Since then I replaced all of the vacuum lines, the spark plugs, the coil and the rubber bellows that connects the air meter to the throttle body. I tried to start it on Saturday and cranked for a long time but couldn't get it to start. On Sunday, after charging the battery I cranked on the engine with my foot halfway on the throttle and eventually got the engine to run. It was running really rough, smoking and it would die as soon as I took my foot off of the gas. After a few minutes of running I shut it down because I smelled gas. There was gas dripping from the clutch bellhousing which is really strange. The top of the motor was dry and none of the gas lines for the K-jet appeared to be leaking. I think the gas was coming from the crank case somehow because when I checked the oil is smelled and looked like gas. Could all of the cranking to get the engine started washed out the cylinders with gas until it got in the oil pan? Did I blow the rings out of one of the pistons? What do you think?
