Old 03-24-2021, 08:30 PM   #1
vishmutzy
Default $20 tach option in 240
I have a base ‘91 245 and wanted a tach. The OEM large meter tach (replace clock) and small 52mm tach (gauge bezel in dash to right of meter) are what I was after but after a few weeks of searching I could find anything reasonably priced.
So I decided to investigate aftermarket. As mentioned above, the OEM small tach is 52mm - same as other Volvo aux gauges - to fit the dash mounting holes. Bosch sells a 2-5/8” tach, but that’s too large without hacking the dash holes. Autometer sells some 52mm tachs and I’m sure they are nice at over $120, but the deal breaker for me was their mounting bracket would be difficult to work in the available space. VDO also sells 52mm tachs, but no online vendors had the 6k or 8k RPM version in stock. Nice thing about the VDO is the threaded ring mounting method that is low-profile enough to fit between the blockoff panel & dash hole.
What I decided to try was a universal (and cheap) 52mm tach which are all over eBay for about $20. They are a knockoff of the VDO tachs in appearance and have the same threaded ring mount. Besides the wiring, all I needed to do was holesaw a 2” hole into a flat blockoff panel and used a sanding drum to open it an extra 1mm diameter. Oh yeah, I also sanded down the height of threaded mounting ring a few mm's as well for clearance between the backside of panel to the dash.
Example item: https://www.ebay.com/itm/392899242355
Wiring consisted of the following:
1. Switched + from fuse 12 open fusebox terminal
2. Illumination + from fuse 16 (made a splitter off of fusebox terminal)
3. Ground - to bolt attaching hood release bracket in front of fusebox
4. Coil signal from white/red tach wire behind meter
vishmutzy is offline   Reply With Quote
Old 03-24-2021, 08:55 PM   #2
2turbotoys
Salaminizer
2turbotoys's Avatar
Use imgur, or if you donate to Turbobricks you can upload them here. Just please do not use photobucket.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 03-24-2021, 09:29 PM   #3
The Librarian
Although it would cost more than you spent on the gauge to buy them new you could have mounted it using the 3 rubber retainers and a stock gauge bezel.
Old 03-24-2021, 09:46 PM   #4
vishmutzy
Indeed, that was my plan but the bezel is backordered (or at least not in stock) and I wasn't sure the eBay gauge surround would fit the profile of the countersunk bezel. It would look better being recessed, maybe I'll add the $5 bezel and rubber retainers to my next iPd parts order and try it.
Honestly the cheap gauge was simply going to be a fitment test jig before I invested in a real VDO gauge (best price I could find is $75), but it works and looks decent so might as well use it until it dies.
Old 03-24-2021, 09:46 PM   #5
James M
Bored member
James M's Avatar
I don't get why people ask $25 for these on eBay when they are $6 new.
Old 03-24-2021, 10:01 PM   #6
vishmutzy
Photos added. Thanks 2turbotoys for advice to use imgur. It's been a few years since my last Volvo (V90 LS1 T56 ) so I need to get back into the turbobricks groove.
Old 03-24-2021, 10:05 PM   #7
The Librarian
'Cuz the dealer websites shows they're discontinued even though they're not.
https://www.tascaparts.com/oem-parts...IFJlc3VsdHM%3D
Old 03-27-2021, 08:30 PM   #8
504
below the surface
What is the source for getting them for $6 new? (The tabs on one of mine just broke.)
504 is offline   Reply With Quote
Old 03-27-2021, 08:38 PM   #9
The Librarian
You can order them at the dealer or buy them from IPD.
https://www.ipdusa.com/products/1656...1259730-105997
Old 03-27-2021, 08:39 PM   #10
My car is fun hp club
You Volvo dealer can order them from Genuine Classic Parts. Or you can order from there as well.
Old 03-27-2021, 10:21 PM   #11
RickATL
Family's fleet manager
RickATL's Avatar
Default Large tachs
Voluparts in Atlanta has used large tachs. I bought 2 from them and I believe they were $50 total.
Feedback thread: https://forums.turbobricks.com/showthread.php?t=353892
91 245 re-christened “The Mistress” 012021
93 244 "Lars"
92 245 "Astrid"
Past
88 245 "Margit" sold
93 244 completely disassembled - It died, so many of its parts could help others live.
97 855 T5
97 855 NA
RickATL is offline   Reply With Quote
Old 03-28-2021, 11:08 AM   #12
DD Ranch
DD Ranch's Avatar
I should get one for my new 90 245.
Voluparts are great. I've used them for years and just got an IAC for my 84 244GL for $45.
Florida Chapter VCOA
DD Ranch is online now   Reply With Quote
