Old 06-10-2021, 11:25 AM   #1
Teeth
Teeth's Avatar
Default b230ft Hesitates at WOT, low rpm
1989 745T, 13c turbo:
Running really well otherwise, but if I really stomp on it from a stop it behaves as if it is either getting too much or too little gas--or too weak a spark to ignite? Happens too early in rpm range to be far into the boost, If I feather throttle slightly, engine comes back and pulls pretty hard. Not a big issue unless I'm drag racing, but, you know, I'd hate to lose the drag race
I did replace the nylon fuel lines with rubber high-pressure lines--which I had a wideband installed to see if was running rich or lean.
Eventually I'll start by pulling the plugs, but posting here to see if there is an obvious answer for this behavior before I start digging.
Proud owner of 89 740 Turbo ratbeater
Teeth is offline   Reply With Quote
Old 06-10-2021, 02:49 PM   #2
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Look at the rubber hose between the turbo and the intercooler. Specifically on the bottom. Is it split? That will cause exactly what you describe. Accelerate hard to get onto the interstate, car bogs down, starts making a wuffling sound, then you let off, and it rockets forward. Had this on an '87 744Ti. Temporarily, duct taped the split section of the hose, and problem went away. Picked up a good condition replacement, never had the problem again.
1982 242Ti - black, M46. 1985 245Ti - blue, M46 - soon to be for sale.
@john242ti on IG
Old 06-11-2021, 06:36 PM   #3
My car is fun hp club
Also the hose from the mass air sensor to the intake of the turbo can get sucked shut causing the the issue you describe. The hoses on the hot side near the turbo get very oily and decay as John pointed out.
Old 07-23-2021, 08:36 PM   #4
Teeth
Teeth's Avatar
Fount it.
Good advice, though I replaced the MAF hose with silicone a while back just to prevent the issue. This time it was just old plugs, bad wires. Gap had eroded out to .040, New plugs, Bougicords and no more issue.
Old 07-23-2021, 08:50 PM   #5
Good work! Nice when it's the simple stuff.
