Old 06-25-2021, 04:10 PM   #1
Bloody244
Default b230R build
So i just blew up my daily driver 138k km b230f+t at 20ish psi trying to overtake a mk3 golf number 4 rod came outside to say hello.
im currently building a new engine its a 92 b230R block
i want it to be bulletproof for 300hp
stock b230 crank
acm.se forged h-beam
mahle cast piston
gasket matched 531 head
v16t cam
also planning to go with a haltech elite 1500
i have heard that the mahle pistons hold 400hp is that true?
'87 244 B230R @17psi 19t V16t cam gasket matched 531 Head ACM H-beam rods Do88 intercooler Accumulator Mod AW71
Instagram @Blue__244
Rip '87 B230f+t it did not stay window free 25.06.2021
Bloody244 is offline   Reply With Quote
Old 06-25-2021, 08:39 PM   #2
My car is fun hp club
If you search around you'll find plenty of testimonials of the stock pistons handling a lot of power. But a proper tune is what will make the engine last. If you don't know what happened to cause the engine failure. It would be wise to make sure things are well sorted out. Injectors flowing to rated flow, fuel supply up to the engines needs, and a stable good tune on the engine.
Old 06-26-2021, 04:39 AM   #3
Bloody244
the engine was hurt because the cam plug blew out and because of that i ran the car with .5 liter oil for 40-45km. i think the rods were bent already because a year ago the boost solenoid didnt work. the boost was around 28 psi with stock lh2.2 sounded like firecrackers. it never ran right after that and huge pressure in the crankcase
Fuel pump is rated for 550 hp
injectors a flow tested and flow 550cc
AFR stayed at 12-11.5 during boost
Old 06-26-2021, 06:26 PM   #4
Fa182
Stage 1
Fa182's Avatar
What's a B230R?
Old 06-26-2021, 06:49 PM   #5
Stiggy Pop
Stiggy Pop's Avatar
Originally Posted by Fa182 View Post
What's a B230R?
There were L and R block castings, the differences seem to be apocryphal and undocumented; but, there are claims of stronger crank journals and thicker wall casting on the R blocks.
'79 242
943 pickup
Old 06-26-2021, 06:54 PM   #6
Fa182
Stage 1
Fa182's Avatar
I see, I've heard about L blocks before.
Old 06-26-2021, 08:02 PM   #7
740atl
Gear acquisition syndrome
740atl's Avatar
The stock mahle pistons are forgiving but only give you a little leeway to detonation.
Old 06-30-2021, 11:51 AM   #8
Jussi Alanko
What turbo is your choice in this build?
Jussi Alanko is offline   Reply With Quote
Old 06-30-2021, 01:07 PM   #9
hk 40
Banned
Originally Posted by Bloody244 View Post
So i just blew up my 138k km b230f+t at 20ish psi trying to overtake a mk3 golf number 4 rod came outside to say hello.
stock b230 crank
mahle cast piston
v16t cam
If you are building an engine from the bottom up I suggest you don't use stock Mahle pistons as the tech has come a long way since then. It not just about holding up. Avoiding detonation is the goal no matter what piston you have in there. The head design also plays a huge part in detonation. What would be nice is a toroidal head design. I wonder would a 4 stroke love it as much as a two stroke does. With such a head the CC can be tightened to the mechanical squish in a 2 stroke and it wont knock and pepper the head and piston. A gas ported skirted piston would be an upgrade to a Mahle. The Pistons ImportTuning used on his build I like alot as they appear to have a high wrist pin mounting location which help to stabilize the piston in the cylinder. The reversed dome petal top piston also looks promising as a piston performance upgrade in an engine build.
Regards
Hubert
hk 40 is offline   Reply With Quote
Old 06-30-2021, 02:25 PM   #10
Bloody244
the 19t from my other engine with the 90+ manifold
also could just buy a custom header
Old 06-30-2021, 02:29 PM   #11
Bloody244
Regards
Hubert
you are back haha. I hope it stays that way and i will look it the pistons more
Old 06-30-2021, 02:43 PM   #12
cosbySweater
cosbySweater's Avatar
I would get a turbo with a bigger turbine on it, the stock pistons will be fine for your power level of that is cheapest and easiest for you to get. Just get a reliable tuner and a good fuel system behind it and you will be fine. Linuxman on the forum here crested 700whp on stock pistons recently.
1995 Porsche 993
2013 VW Passat TDI
Old 06-30-2021, 02:50 PM   #13
Bloody244
the problem is that i made the tests needed to make my car street legal with the 19t so im stuck with it, if i get a hx30 i have to pay around 1500€ just for tests and still have to register it to the Tüv and insurance.
Old 06-30-2021, 02:53 PM   #14
culberro
culberro's Avatar
Sure hope it was a turbo vr6
Skip the gasket matching, you're only going to make things worse for flow. Send the head to a knowledgably porter, or open the chamber and port the exhaust bowl and SSR yourself.
Stock turbo pistons will be fine for your power levels. Forged pistons will take ever so slightly more abuse, but you can still kill them in a few seconds with bad tuning. Forged pistons can also wear out faster depending on a few things.
Old 06-30-2021, 03:17 PM   #15
cwdodson88
+1
Also, forged pistons usually run looser piston>wall, so more cold piston slap, more cold blowby, more possibility of bad/initial tuning to cause catastrophic engine failure if your not on top of things.
The Build Thread
SVEA - PUSHROD TURBO!
Old 06-30-2021, 03:25 PM   #16
JohnMc
JohnMc's Avatar
On the plus side, if you do have some issues along the way, you'll probably have to pull the motor apart and replace things, but there's a far better chance that it won't completely self destruct and require an entire new motor.
I pinged one set of forged pistons to death due to a lack of fuel pump capacity - broke the top ring, collapsed the top ring land... but the pistons hung together, so I was able to take it apart and rebuild it due to low compression, not due to it throwing a rod and scattering bits all over the road. And another time (which I can't really believe happened) when a wrist pin broke, I drove it a decent number of miles (even with some full boosty pulls) with a 'lifter tick'. Could a stock cast Mahle piston hang together with only one half of the pin holding it in? Probably not.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 06-30-2021, 03:31 PM   #17
hk 40
Banned
you are back haha. I hope it stays that way and I will look it the pistons more
Thanks! That's politics for ya....but it doesn't truly stop anything. Were still building and sharing inclusively with our real friends here and abroad. Im very happy in my life and nothing can change this or how things really work. Please take an in depth look at modern piston tech. There's alot of improvement to be had there.
Good luck
Hubert
Old 06-30-2021, 03:38 PM   #18
Bloody244
it was a 90 hp tdi haha
it was gasket matched when i got it. im going to order from overboostracing.se a stage 2 or 3 ported 531 head with larger valves
Old 06-30-2021, 04:12 PM   #19
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I'm not sure you'll get much out of a ported head with the 19t, the problem is the hotside is fairly restrictive on even the biggest td04's. I'd save that money for now, and if you decide to re-cert it later with a more modern turbo, re-visit it if you feel it's a restriction. At 300hp however, even a stock 530 head isn't really much of a holdup. I would second the longer rod/higher pin thought process, there are trade-offs that some folks will argue until they're blue in the face (and you can probably search those threads out if you'd like), and I believe you can bump the rod c2c up from the stock 152mm to 160 or a little more, and still retain a decent ring pack. It's been admittedly a while since I've looked at the specific numbers, but the long rod 2.5 I put together in 09 did quite well until the block itself decided to spoil the fun.
On the subject of stock pistons (Since you asked), I've personally had the NA pistons in my 16v car up to 670whp at around 40psi, any number of people have made over 300whp for quite some time with na and turbo pistons, so if you were required to use them (doubt tuv would open the engine up though) I wouldn't really worry about it, but if you can run newer stuff I think you'll like how it performs a bit better over the OE stuff.
Megasquirt Tuning!
Old 06-30-2021, 04:29 PM   #20
culberro
culberro's Avatar
100% this.
Old rally race motor sat for ~ 4 months and got some rust in the bores in that time. Upon start up, the rust chewed up the thin ring pack which caused excessive blow by. Engine made it about 3 min of racing before it holed 2 pistons and pushed most of the oil out through the breather.
Old 06-30-2021, 04:48 PM   #21
hk 40
Banned
High wrist pins mitigate alot of piston slap. I consider detonation a poor enuf tune and the Mahle is there with the results of that. No piston performs well in a poorly tuned motor. No motor will hold up under intense detonation which should really be no issue with 550cc injectors @ 300hp with capable tuners. Poor tuning should never be a consideration in my mind.
Old 06-30-2021, 04:59 PM   #22
culberro
culberro's Avatar
In my case, the tune was good, the engine was used for a few years prior and showed no issues on inspection before the race car was stored. The blow-by oil diluted the charge and significantly lowered the octane rating. It only exploderated the pistons that were in bores that showed signs of rust.
Doesn't really matter. The new engine makes more power and torque using stock cast volvo pistons
Old 06-30-2021, 05:03 PM   #23
hk 40
Banned
Thats great but even Volvo amends them for more power. Group A is skeletonized One car experience does not deem a cast piston over a forged one. The argument about strength is a no brainer and clearly the world of high performance and durability usually comes at forged offerings. All things equal and done correctly you wont out perform a good gas ported forged piston with a old cast Mahle. I better explain that none of this means he cannot run a stock mahle in a 300 hp redblock. But better is still better and there's no point in skewing the facts. The truth does actually matter.
Old 06-30-2021, 05:47 PM   #24
cwdodson88
It’s all good til the guy slaps a set of 1000s on it and drives a cold engine to the tuner just to find out that he’s 2qts over filled with gas and old Rodney starts knocking like 7.3idi.
Old 06-30-2021, 10:19 PM   #25
Marvelous3
Who engineered this?
Marvelous3's Avatar
the engine was hurt because the cam plug blew out and i ran the car with .5 liter oil for 40-45km. i think the rods were bent already because a year ago the boost solenoid didnt work. the boost was around 28 psi with stock lh2.2 sounded like firecrackers. it never ran right after that and huge pressure in the crankcase
So what you’re saying is your marginally neglected the engine/didn’t do some solid moding to start with.
You can do 300 no problem on stock bottom end parts.
