Old 07-07-2021, 11:00 AM   #1
rearwheelpeel
rearwheelpeel's Avatar
Default 1983 245 ac r134a conversion parts needed
We have a customer that wants his 83 245 converted from r12 to r134a. The volvo kit is nla and that is all our parts department is apparently capable of looking at. I have been tasked with figuring out exactly what is needed to do this. Im finding all sorts of conflicting information regarding swapping evaporators, driers, thread pitches etc... can anyone tell me for sure what parts we are going to need? This car is all original. Thanks in advance.
rearwheelpeel is offline   Reply With Quote
Old 07-07-2021, 12:05 PM   #2
Khrrck
Professional Amateur
Did you see this thread? I think it's the most comprehensive resource we have right now:
http://www.forums.turbobricks.com/sh...d.php?t=356477
'87 240 budget wagon.
Old 07-07-2021, 12:20 PM   #3
volvowagoon
volvowagoon's Avatar
This will really depend on how much or how little you want to work and spend. You can do the conversion with as little as just the refrigerant itself, flushing agent, and ester oil as long as you you have the right tools and don't cut corners. It won't preform very well though. Being in NY you might consider it adequate, but I doubt you would on a hot summer day.
Our '89 already had the dealer installed compressor and TXV which you can still buy from FCP. I flushed my system, replaced the oil, replaced the drier, replaced the fill fittings, drew a vacuum for a couple hours, made sure it held, and filled the system. It's been blowing cool for over a year now. It's hot for back seat passengers in the summer time, but it's adequate for the front on MAX.
I'm not sure if the newer style compressors will work in an '83. You might need new accessory brackets, but I know the early compressors kinda suck. If you don't want to get that invasive in your stock car, I would look into just flushing, vacuuming, and filling with duracool or similar. R-134a probably won't have enough beans.
1986 Buick Grand National - Restored to stock™
2002 Camaro V6 T5 +T - The trashy car that's fun to drive
2010 C30 T5 - The boring but trusty daily - 199k
1989 245 DL - The boring but not trusty daily - 233k
IG: @v6buick
Old 07-07-2021, 04:02 PM   #4
2manyturbos
Just charge the system with Envirosafe ES12A and be done with it. It will get as cold as it did with R-12 and the Envirosafe is less likely to leak. You don't even have to flush the system or change the oil.
Old 07-07-2021, 04:54 PM   #5
rearwheelpeel
Thanks everyone. I’ll have our service manager read through all of this and talk to the customer. He bought the car new from us in 1983 and has kept it in mint condition. He apparently had a stock pile of r-12 that just ran out.
Old 07-07-2021, 05:08 PM   #6
2manyturbos
Go onto Envirosafe’s website and read up on ES 12A. It is a direct, drop in replacement refrigerant. There is no point in putting a lot of money into converting that system to something that won’t work anywhere near as well as his current system will with ES-12A in it. ES-12A is cheaper than R-134 and you don’t even have to be licensed to buy it or recharge it.
Old 07-07-2021, 06:16 PM   #7
rearwheelpeel
Yeah I’ve been reading about it. This sounds like the best way to go. Thanks!
Old 07-07-2021, 06:26 PM   #8
2manyturbos
It is certainly worth a try. If your customer doesn’t like it, then you can discuss the several thousand dollars it’s going to take to retrofit his car. I’ve used ES-12A in Volvo systems and it works great.
Old 07-17-2021, 02:15 PM   #9
stove
stove's Avatar
+10,000 for ES
stove is offline   Reply With Quote
Old 07-19-2021, 08:57 PM   #10
nel621
Does ES-12A use the same type port as r12 for charging? Also I have 134a gauges. Are r12 adapters available for these gauges?
Old 07-19-2021, 09:06 PM   #11
2manyturbos
ES-12 is set up for R134 charging equipment. Just get an R-134 conversion port for the R-12 system and you’re good to go.
Old 07-20-2021, 08:53 AM   #12
nel621
Then I'm set, thanks.
