alschnertz
Enough already!
- Oct 4, 2009
- CT
1986 745T 162,000 miles
I installed a new in-tank pump this afternoon as preventative maintenance.
The new pump (Delphi from FCP) was not as long as the original, but the diameter was the same and the connections too.
Upon starting the car afterwards, the main pump sounds awful. Groaning like it has a bad bearing. It didn't make the noise before replacing the in-tank pump.
There's about 3/4 tank of fuel in there.
I know there is a way to jump the fuel pump relay to get just the fuel pump to run.
Is there a way to isolate the two pumps when doing this?
In other words, I'd like to test the in-tank pump and the main pump separately.
Could it be that the new in-tank pump is groaning and the noise is making its way to the main pump? The sound I hear is near the main pump.
I'm pissed that I didn't check the new in-tank pump on the bench before installing it.
