- Feb 20, 2005
- Mountain View, CA
I actually just lol'd.All that means is that you haven't spent enough time on TB.
Keep up the good work Nathan.
All I really need is a base gasket and your restrictions...if you were to give me dimensions like it can only be X out from the head, and Y up from the head and I want the TB in about this location, or if you like my plenum......the build is pretty easily done, just takes some hours to make it all happen. Should be fun
Notice how on the stocker the runners are laid down much more than just coming straight off the head, we had to clearance the heck out of the runners to make room for the injectors. Sure it is far from ideal by blocking flow but figure I still have a stock head on the car so that little bit is far from as large of a restriction as that stock manifold itself was.
One train of thought is to aim the injector so the gas hits the back of the valve to aid in vaporization. Have you noticed if the OEM manifolds you measured actually do this?
Richard
Nathan, I guess it's still in mockup mode, but that throttle body transition looks like a real dog's breakfast IMO. .
looks great IMO
It doesn't even line up to the plenum. Are you retarded?
This place just kills me some days.
