quillc
yv1a.com
- Aug 19, 2008
- Kitsap, Wa
Hi all,
Looking at (finally) installing my TrueTrac high preload LSD in my DD. I'm changing to a 3.73 gear ratio from the 3.31 that are in the car now.
Looking for anyone else's experience setting one up.
1. Did you measure pinion depth?
2. If you did, what tool did you use?
3. When installing your TT, did you swap gears?
4. Did you have to adjust your shims or did you get lucky and the factory shims were bang on?
5. Did you use a crush sleeve, or did you go with shims on the pinion?
6. Who did you get your install kit from (bearings, shims, etc.).
thanks!
thanks!
