Old 03-14-2021, 10:22 PM   #126
atomicdeathmonkey
atomicdeathmonkey's Avatar
Originally Posted by bobxyz View Post
Nice progress! Check the wiring diagram, but some (or maybe all) years of K-Jet have a wire from the coil "-" tab to the fuel pump relay (and to tach, if any). The fuel pump relay only turns on once cranking, and spark, is detected. It's a safety thing - don't pump fuel when the engine isn't running.
Will do man, I did change the coil so may have put something where it didn't belong! Thanks!
Time to wash out the cooling system. Nothing terrible, all clear water and a little sediment, no rust !
More than a bit of a process.
I have all new hoses and I'm cleaning up the t junctions.
Tested out the new thermostat
My overflow tank has a good bit of pitting on one side, may need to replace it?
Looks like someone used sealant where it meets the bracket too.
There was no thermostat in it !
Threw the cleaned up idle air control valve back in, fiddly thing to get the bolts in!
The front splitter clip had disintegrated see o quick but if cable tie action !
More on the rebuild of the coolant system later,all the hoses red rotten! Hope my heater core is okay !
Volvo 242 turbo intercooler 1984, w124 300d, toyota big fridge, small toyota washing machine.
atomicdeathmonkey is offline   Reply With Quote
Old 03-15-2021, 12:51 AM   #127
atomicdeathmonkey
Boring stuff here for the most part, had to improvise some brazing with the solder I had on hand for one of the pipe t's. Used a bit too much sealant but got some pretty even squeeze out ;)
Little jobs tonight so they'll be all cured for tomorrow!
Old 03-18-2021, 01:46 PM   #128
245tic
I had to just purchase new tees. Mine were rotted thorough. Nice work!
245tic is offline   Reply With Quote
Old 03-18-2021, 11:03 PM   #129
atomicdeathmonkey
Originally Posted by 245tic View Post
I had to just purchase new tees. Mine were rotted through. Nice work!
Yeah, I might be buying new ones too - that or pipes that are a bit smaller. Did a water test and it took a leak immediately!
20210317_170956 by V G, Flickr에서
Some new shiny hoses
20210317_134353 by V G, Flickr에서
20210316_204459 by V G, Flickr에서
20210317_134343 by V G, Flickr에서
20210317_134356 by V G, Flickr에서
Next was to figure out some injector issues - just bought new ones!
20210318_151259 by V G, Flickr에서
20210317_184458 by V G, Flickr에서
20210318_151701 by V G, Flickr에서
Took off the injector lines - was afraid of them twisting or breaking - try finding a replacement!
20210318_155252 by V G, Flickr에서
New crush washers from m1 autohaus
20210318_152139 by V G, Flickr에서
20210318_182131 by V G, Flickr에서
Got my spacers too!
Had to give the firstborn a wash - going on a month without any water on it!
20210318_175129 by V G, Flickr에서
Old 03-19-2021, 05:37 PM   #130
swedishiron.com
I sell Volvo parts!
I have new Volvo water Tees if you are interested.
I may also have a spare fuel injector line or two.
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
Old 03-20-2021, 12:43 PM   #131
atomicdeathmonkey
Thanks, man - I just ordered them on VP parts yesterday! the injector line survived but i'll keep you in mind next time !
YouCut_20210320_111508995 by V G, Flickr에서
So she'll run if I manually actuate the kjet fuel distributor, the engine runs and that's good enough for now, I've to work my way through the troubleshooting guides and see why she needs so much help!
I'm waiting on one of the connector pipes for the cooling system - though I got away with the repair on mine but it's leaking from the seam and a few more pinholes!
Screenshot_20210319-211632_DuckDuckGo by V G, Flickr에서
Old 03-21-2021, 01:34 AM   #132
atomicdeathmonkey
To avoid getting static in terms of progress I decided to get the cross threaded wheel stud out of the way! $16 sae set from harbor freight and a bit of luck and got the threads cleaned up.
20210320_163824 by V G, Flickr에서
20210320_165745 by V G, Flickr에서
20210320_165911 by V G, Flickr에서
20210320_172259 by V G, Flickr에서
20210320_174418 by V G, Flickr에서
20210320_180225 by V G, Flickr에서
20210320_180240 by V G, Flickr에서
20210320_190333 by V G, Flickr에서
New coolant bottle and cap fitted
Lots more plasti-dip to remove from the old wheels.
20210320_190343 by V G, Flickr에서
Nice filling of the arches now with the spacers
20210320_195923_001 by V G, Flickr에서
20210320_192523 by V G, Flickr에서
Old 03-22-2021, 12:10 PM   #133
Murploid1
Murploid1's Avatar
On the advice of a more learned member in terms of these cars I removed and cleaned the idle air control valve too and it was stuck.
Can you tell me the location of that idle air control valve?
Murploid1 is offline   Reply With Quote
Old 03-23-2021, 01:21 AM   #134
atomicdeathmonkey
It's right under the intake manifold, towards the rear of it, undo the two pipes going into the throttle body and undo two ten bolts I think they were, it will also have an electrical connector to remove on it.
Old 03-23-2021, 09:09 AM   #135
atomicdeathmonkey
Got distracted with a smoking deal on some storage and hardware, $50 all in so took the weekend to organise my garage.
20210320_224109 by V G, Flickr에서
20210320_224935 by V G, Flickr에서
20210322_151308 by V G, Flickr에서
I really should put some paint on the walls at some stage.
Old 03-23-2021, 11:20 AM   #136
Murploid1
Murploid1's Avatar
Hmmm interesting. Not sure my car has one. Its a 1982 Kjet turbo car. I don't remember seeing that and i have had the intake manifold off.
Old 03-23-2021, 01:46 PM   #137
kampman
dunning-krugersquirt
Every US market Volvo got electronic idle speed control starting in 1981 so your car should have it. No guarantee that someone hasn’t played Volvo lego in the intervening 40 years though.
1984 245T
2006 V50 T5M
Feedback Thread
Old 03-28-2021, 03:39 PM   #138
atomicdeathmonkey
20210325_163815 by V G, Flickr에서
Got the right part thanks to a member on here giving me the links! very much appreciated!
20210325_164232 by V G, Flickr에서
New clamps on everything!
20210325_173529 by V G, Flickr에서
made sure to use the right coolant :D
Confirmed it was the right color when it came pissing out the back of the head somewhere.
This car really doesn't want to be on the road!
20210327_144438 by V G, Flickr에서
Old 04-12-2021, 10:37 PM   #139
atomicdeathmonkey
Time for new battery cables, slow starter and serious heating up !
These are the sizes in first pic if you ever go near an old 240.
Got distracted by a pretty heavy oil leak in the truck! Thankfully sorted quite quickly, I love my Toyotas ;)
Tried to check the timing, can't see any of the flywheel marks, have the belts on order so I can reach when I take off the timing belt cover to check.
No power at the #30 pin of the fuel pump relay with key off so have to chase that.
No bounce in the tach so I've ordered the pickup/ hall sensor, I have a spare distributor here with a new sensor/ pickup lead but I can't get the current distributor out!
Hopefully I can put this new sensor in with distributor in place?
Quick vid of her turning over now, much better than it was, after the cables and cleaning up grounds
https://flic.kr/p/2kSDKy1
Old 04-24-2021, 04:18 PM   #140
atomicdeathmonkey
Scored this sweet tool tray, bluepoint job and it's cleaning up very nicely. I don't know what they cost new but I'd expect it was multiples of the $100 bucks I gave for it.
So the hall sensor, I don't have a needle nose circlip thingy and I can't get the pickup wiring screw to turn at all in the car...
Thought I'd remove the distributor and do it on the bench.
That thing won't move for love nor money, have had it soaking a week in oil/ penetrating stuff and it won't budge.
Think I'll need a sky hook ;)
Project pain in the hole continues...
Old 04-25-2021, 10:52 AM   #141
atomicdeathmonkey
My milkshake brings all the ..... Feck!
Thinking on just pulling the whole engine.
Literally everything mechanical/ electrical so far has needed going through and I don't want to rush things/ can't due to time and finances anyways.
Maybe whipping the engine out and checking all on the stand would be handier ?
Old 04-25-2021, 11:49 AM   #142
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Crush it
Old 04-25-2021, 11:47 PM   #143
atomicdeathmonkey
Crush it
Lol 😂 thankfully it can take it's sweet time!
we ran some compression tests and it's allover the place 95 in one, 129 in another, 110 in other two so bottom end / piston rings will need looking at.
I'm thinking of picking up a b230 engine from a newer 240 and nail my turbo bits onto it, run megasquirt and be done with it!
I'm pretty tired of the unobtainable kjet bits at this stage.
I did manage to distract myself with some mates' cars today. Full paint detail on a w123 which took the crazing out and I'm getting that pinto wagon waxed come Friday for a show.
I'm half decent at detailing but these guys have full on nova drag cars and pinto powered goodness so I'm learning about engine swaps with them close by.
Old 04-30-2021, 09:47 PM   #144
atomicdeathmonkey
And the manifolds were surprisingly easy to remove. Stopped until I can get some light to get the belts off. Then liberation of the head shall commence!!!
Old 05-01-2021, 07:07 PM   #145
atomicdeathmonkey
It's very satisfying taking things apart, I'll give it that.
So head is off, a bit of a lip at top of cylinders.
I'm going to drop off the head to a local shop and see if it's salvageable. The threads for spark plugs are filthy and two seemed to be crossthreaded before.
Looking at the gasket I can see two areas the coolant could have mixed with oil passages.
An engine I was hoping to get was sold by time I got to it. Hoping to have the option of a decent b230 to throw into it if it comes to it.
Time to start thinking of a replacement engine too possibly. Going to get the head looked over and see if what I have is realistically rebuildable.
Tempting to go for a later b230 to at this stage
Old 05-02-2021, 08:57 AM   #146
white855T
Not to make things worse but that turbo looks done as well. Normal things when you deal with an old engine.
Old 05-03-2021, 12:48 AM   #147
atomicdeathmonkey
I figured going by the amount of crud on that side of the engine. It's like archaeology at this stage!
So soon we'll see if the head is salvageable, then I'll probably whip out the rest of the engine and get the whole thing rebuilt!
I really wish I'd taken a before pic of my engine stand. It's a homemade affair I got for free.It was crusty, so it got the end of the strut brace paint.
Then these s80 rims came up local for $50. I have no self control!
Old 05-04-2021, 10:34 PM   #148
atomicdeathmonkey
Head has a tiny crack between the valves, really thinking of a b230ft if I can find one at this stage
Old 05-15-2021, 04:48 PM   #149
atomicdeathmonkey
So took a run to the scrapyard and found a 1992 Volvo 940 engine with 100 k miles, getting the exhaust manifold & turbo off this 740 too!
Hoping my old power steering pump will fit!
Will have to convert the engine to run a distributor in the block too!
Would have preferred a 90-93 240 engine but that's what's local !
Old 05-15-2021, 04:51 PM   #150
atomicdeathmonkey
So got the engine home and beside the car
1992 Volvo 940 engine 100k miles, looks clean as under all the dust.
Got the turbo bits off a 740 they had there too.
