Old 05-04-2021, 07:19 PM   #26
Alex Mcknz
The progress looks nice, I am excited to see how it will turn out.
Alex Mcknz is offline   Reply With Quote
Old 05-05-2021, 11:47 AM   #27
R32RennSport
Outlaw Amazonian
R32RennSport's Avatar
Originally Posted by spock345 View Post
Recently got a big score for the car. An M410 with the rare B20 bell housing. I'll have to put some work in adapting it for a hydraulic clutch. My hope is that I can figure something out that doesn't involve cutting or drilling the bell housing. Maybe forced induction is a possibility in the future.
Nice
Steven
1966 Outlaw Volvo Amazon, 2004 VW R32 Golf
R32RennSport is online now   Reply With Quote
Old 05-07-2021, 05:58 PM   #28
spock345
spock345's Avatar
Waiting on some parts. So I decided to give the gearbox a new coat of paint with some of the red I had left over from the engine. I found bits of the original dull red and some black paint on it. After some thinking this gearbox is probably overkill for what I will actually end up doing with the car (as opposed to wishful thinking). I'll use it for the time being while keeping an eye out for an M41. Most of what I need to do carries over to the M41 anyway
I've got to clean up one or two spots of over-spray. Doesn't look too bad for a paint job done during a lunch break.
1967 122s, B20F, M40
spock345 is online now   Reply With Quote
Old 05-07-2021, 06:05 PM   #29
carver
Redblock for life.
carver's Avatar
You were not kidding about the crate...
Old 05-07-2021, 06:08 PM   #30
spock345
spock345's Avatar
I inadvertently got a good amount of scrap wood. I am pretty sure there is 40-ish lbs of wood and deck screws in that crate. Given what lumber is now going for the previous owner probably could have packaged it in gold. They even bolted the gearbox down inside in three spots.
I just have to swap the OD flange and top cover. Then it can go in the car. If I recall correctly I can test the four speed part of it without wiring up the OD solenoid. So I'll likely do that to do my own test for noisy bearings and synchro function before making a new harness for it.
Old 05-07-2021, 07:45 PM   #31
joel142
I have the long handle shifter in the 142 (it's a '71) and while it's murky and slow it's got a great old school vibe. It's shifting like you mean it!
'71 142E, M41, Corbeau GT seats, iPd bars and springs, Nardi wheel, GT gauges, overmatched KYB Gas-A-Justs, Canisto wheels, 7" and Series 175 Cibies
'95 T5-R, yellow, M56H swap
joel142 is offline   Reply With Quote
Old 05-08-2021, 06:56 PM   #32
spock345
spock345's Avatar
I definitely want the long shifter but apparently there are some incompatibilities between the two setups. I am not sure if I will be able to make it work.
Old 05-08-2021, 07:13 PM   #33
spock345
spock345's Avatar
Also I am not sure how much play the input bearing on an M40 is supposed to have. I pulled mine today to grab the top cover and investigate a leak. Either way it may need some work.
https://i.imgur.com/8xcWcD8.mp4
Old 05-08-2021, 10:18 PM   #34
joel142
I just gave the spare M41 in the garage a jiggle and I can't say it's much different. The rando off craigslist I bought it from assured me it was mint.
Old 05-08-2021, 11:50 PM   #35
spock345
spock345's Avatar
I'll probably rebuild the M40 as a spare at a later date. Seems like a relatively easy gearbox to learn how to do it with.
The only reason I bought that M410 from craigslist is because paypal protections and the rather rare bell housing for a low price.
Old 05-09-2021, 11:53 AM   #36
spock345
spock345's Avatar
Update, drained the oil in the M40. It is glittery. That combined with a messed up input shaft bearing means it gets to come apart.
I started the disassembly process and all the gaskets were slathered in badly applied RTV. This bodes well.
Old 05-09-2021, 01:46 PM   #37
spock345
spock345's Avatar
Tore down the M40 for fun to see what the cause of the glittery oil was. I thought it would be harder, only took about 45 minutes to do. Turns out I have one bad synchro (teeth sheared off), chunks out of the reverse idler gear, a bad lay shaft, pitted bearing surfaces in the lay shaft gear cluster, and both input and output main bearings could use replacement. Oh boy.
Old 05-13-2021, 09:31 PM   #38
spock345
spock345's Avatar
Default Gearbox fully torn down
Had some difficulty getting the rather badly chipped reverse idler gear out. Also got the main shaft apart to replace the bad synchro. Painted the case because there wasn't much paint left under the grime.
