Old 11-16-2020, 07:33 PM   #751
Duder
Comes with a free Frogurt
Duder's Avatar
Originally Posted by Alex Buchka View Post
Thanks! I can't imagine it either, if my mind wanders in that direction it reminds me of how much work is left and I get depressed. Just eating this elephant one bite at a time.
You can borrow my Miata again if you need to get behind the wheel of a purebred track beast. I'm sure the driving experience will be identical to the FRC.
I need to make it out to the shop more often - you guys are killing it. Also I hadn't realized how low this thing will be, but it makes sense. Slammed AF.
Old 11-16-2020, 07:42 PM   #752
Tfrasca
Tfrasca's Avatar
This will be the best car in the world.
Old 11-16-2020, 07:45 PM   #753
Bet it gets air conditioning, cut wool pile carpets, and leather padded touch points on the spaceframe too.
Old 11-19-2020, 06:07 PM   #754
tjanson
tjanson's Avatar
Do you treat the wood build table as a rigid fixture or is primarily to support the chassis and act as a reference plane? I've thought about making a welding table out of engineered lumber, topped with 12 gauge steel because it seems easier to make flat without the warpage that comes with welding.
1993 245 DL; LH2.4, M47 - DD & Winter Beater
1978 242 GT - To Be Restored, someday
1993 245 DL - OEM+ Project
tjanson is offline   Reply With Quote
Old 11-20-2020, 07:51 PM   #755
Alex Buchka
8 cylinders
Alex Buchka's Avatar
I would be honored to try and ruin your track beast again.
Don't forget the TV's, champagne chiller, and sno-cone maker.
It's mostly the latter. The table does have more compliance than I would like so as long as you're cognizant of how much weight you're putting on there it should stay flat enough. This table was always a temporary structure and we're nearing the end of its useful life. It'll get scrapped soon and the chassis will sit on jack stands for the remainder of the build.
Control arm fixture is ready for action. Each counter-bored pocket gets a brass spacer slug that presses into a uniball weld cup, those will then get connected with 4130 tubing. The two rectangular plates in this pic suit the four left hand arms, there's another pair of mirrored plates for the right hand arms.
Got the first corner's worth of suspension brackets tacked in place. Getting the fixture lined up took a few hours of adjusting and careful measuring. This first corner was pretty time consuming since I was essentially establishing the datum for the other three corners, the remaining tabs should progress pretty quickly. Having the mounting tabs laser cut to near net shape was also a big time saver.
The steering rack set the fore-aft position of the suspension mounting locations so I took the opportunity to finish up the attachments for it as well. The machined clamp collars that go on the rack were done a while ago so all I had to do here was transfer punch, drill the front bulkhead, and weld in four pieces of tubing the rack bolts to.
Old 01-12-2021, 04:50 PM   #756
Alex Buchka
8 cylinders
Got a big box of 3x.035" inconel 625 tubing for the exhaust. Going into this I was intending to make it all stainless but I made a throw away phone call to Woolf Aircraft to see if they had any surplus and I ended up getting everything we needed in inco for 321 stainless prices. Some of the bends are a little wrinkled but it doesn't really matter to me.
Exhaust manifolds came back from welding. Couldn't be more satisfied with how the welding came out, the guy who did the work is an ace with the TIG. All the joints are welded in one pass and look phenomenal.
Fit checked the blurbos and everything is looking really good so far. All the clearances are as expected, really excited to build the exhaust and get some plumbing on these things.
Old 01-12-2021, 05:30 PM   #757
amazing
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 01-12-2021, 05:39 PM   #758
Stiggy Pop
Stiggy Pop's Avatar
I can certainly understand why you made the comments elsewhere that this is a "motor swap only a mother could love". I'm glad you guys are taking it on.
I've been interested in the additive processes you've used, and chatted about it with some with buddies at work (I'm in manufacturing). I'm curious if you've taken that route out of design requirements, equipment access, a desire to experiment, or some combination of all? Some of those pieces represent some pretty significant amount of machine time! We have started getting more involved with additive inconel processes with some heat exchangers.
'79 242
943 pickup
Old 01-12-2021, 06:38 PM   #759
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
What are the advantages of an inconel exhaust?
I sell chips for LH 2.4!
redblockpowered is online now   Reply With Quote
Old 01-12-2021, 06:58 PM   #760
Alex Buchka
8 cylinders
Thanks dude. We're all in on the B8444s sunk cost fallacy at this point.
The additive stuff was initially driven by machine access. We've been fortunate enough to build a relationship with a local shop that does really high end work and the owners are sympathetic to the FRC cause. The headers and intake manifold were definitely tough packaging problems that were a bit easier to solve with the "free" complexity of DMLS. Another big part was the design challenge, I'm heavily accustomed to designing 3+2 machined parts so I had to unlearn a lot of that mindset when designing for printing. I like solving problems and this was a big nut to crack. You really have to think of the end-to-end process in the design phase so you don't paint yourself into a corner.
Feel free to PM me if you want to chat more about it. Additive is not a replacement for machining but it can be extremely cost effective in the right application.
Over 321 stainless, not a whole lot. Post-turbine EGT is low enough that it's not really necessary but it will make the exhaust lighter and more durable over time. Especially when you start applying thermal barrier coatings to the outside of the tube that drive the material temperature up.
Old 01-13-2021, 10:54 PM   #761
Duder
Duder's Avatar
When you already have a tube chassis, Indycar transaxled, twin turbo V8 242, it would be rude not to use Inconel for the entire exhaust system!
Old 01-15-2021, 03:26 AM   #762
Alex Buchka
8 cylinders
Seconded!
Got some more parts in the mail. Ordered a couple v-band flanges for the downpipes:
Got a few really slick oxygen sensor bungs from Reid Washbon. It's the little details and these things are primo. Also came with a free notepad:
Lunched this bearing taking it off. Cost me $80 and a bruised ego. This is the back business end of a torque tube from a C5 vette and is part of what makes the xtrac magic happen:
Pulled the drop gear cover off the xtrac to machine a hole in it for the reverse lockout. The small post to the left of the center shaft is the reverse selector shaft, this is what the lockout mechanism blocks from moving.
The insides of this gearbox are amazing. It's like a jewelry box.
Had to stop and check wipe a few times during this operation. Screwing it up would have been grounds for ritual suicide.
Then Karl and I had a potential Corona exposure event so we've been locked in the apartment for the last week. I took the time to order up a mountain of laser cut brackets that arrived today. I've been using sendcutsend.com for the last few orders and they really kick ass. Super clean cuts, excellent prices, and crazy fast delivery. This entire pile took four days from order to arrival.
This heap is mounting brackets for the dash display, current sensor, yaw sensor, heat exchangers, and wastegate actuators, end tanks for the rad, oil cooler, and intercooler, main hoop bulkhead panels, wiring bulkhead brackets, and weld-on rivet strips for various things.
Old 05-02-2021, 05:08 AM   #763
towz-T
EL hipo explosive
towz-T's Avatar
Pro: Super light, heat resistance properties.
Cons: PITA to work with (apperently). Very expensive.
F1 (and some others high end race cars) exhausts at Inconel 625. They can be made extremely thin and therefore light, and also because of the great heat resistance properties.
Also used in nuclear reactor cores and spacemachineshiprocketthings
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
Old 05-03-2021, 04:25 PM   #764
liamcafs
I love this thread, its such a great read........ Oh and by the way, completely by coincidence, I just bought a B8444s to swap into my 240 wagon.
https://imgur.com/nfUzXAk
liamcafs is offline   Reply With Quote
Old 05-03-2021, 05:18 PM   #765
HiSPL
HiSPL's Avatar
I hope you've got the skills to pay the bills. It's an incredible motor for a 240, but its so hard to make it work. It's also easy to find and cheap to buy since the transmissions grenaded on so many of them.
Keep us up to date!
Beets taste like buttfeet.
88 244
06 XC90 V8
03 V70
HiSPL is online now   Reply With Quote
Old 05-03-2021, 05:36 PM   #766
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Everything you guys do is the sexiest thing ever
Old 05-04-2021, 11:56 PM   #767
Alex Buchka
8 cylinders
Thanks! You should make a project thread, I'd love to see your progress.
That's debatable, but thank you!
Ran low on motivation for a stretch but we're back at it now. I had the previous week off in between jobs so I made a big push to finish up the control arms.
I was a little worried I'd gone overboard on the fixture for the arms but after using it for the past few days I actually could have made it a bit more rigid. Welding distortion can exert tremendous force and the 1/4" aluminum base plate does get a little bendy at times.
The outer pivot is located on the smaller common plate. The larger plates are made in unique pairs for each side of the car. The bearing cups get pressed on to some brass standoffs that both locate the endpoint at the right height and keep the ID from distorting during welding.
Arm construction is fairly simple. 4130 tubes and spherical bearing weld cups. The lower arms have some sheet metal gussets where the damper mounts will get welded on.
Took a few arms to get the process dialed. All the tubes are larger OD than the height of the bearing cups so the ends all got smashed down in the press, then trimmed with the notcher until they fit nicely.
Welds got progressively nicer as i got into the process. I don't fabricate stuff for a living so I'm really happy that I can maintain reasonable consistency even after a month+ hiatus from the TIG.
So far I have six out of eight complete less damper mounts. The remaining two rear upper arms are a bit more complex to accommodate some less than ideal damper packaging. They will get some additional taco gussets for peace of mind. I fabricated this forming tool out of literal trash I found laying around the shop. It's not the slickest thing to use but I'm only forming a handful of gussets so it does the job.
Welded up the yaw sensor mount.
Started adding some paneling.
Made some jack-screw doodads for the xtrac. Everything on this gearbox has threaded inserts to aid removal, pretty slick.
Picked up a flush mount fuel filler.
Spent a bunch of time welding and blending this sweet mounting bracket for the stack dash, then i sat in the car and realized the rim of the wheel blocks the view of the entire tach. Derp.
Picked up this carbon diffuser from an NSX GT3. It's a bit rough but all the bad parts will get trimmed off anyway. It will actually fit with the bodywork pretty well. Having this part is a welcome constraint to the design space of the rear of the car. It's a good forcing function to derive the design of the rear structure.
Old 05-05-2021, 09:54 AM   #768
Mueller
Mueller's Avatar
Hot Rodders Hall of Fame car right here. ^
Mueller is online now   Reply With Quote
Old 05-05-2021, 10:11 AM   #769
slick!
Old 05-05-2021, 09:59 PM   #770
Duder
Duder's Avatar
You guys should take a break from all of this FRCing so we can finally finish the pickup bed.
I am still looking forward to never being allowed to drive it!
Old 05-07-2021, 10:01 AM   #771
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Ugh. Freaking epic! That diffuser is bad ass!!
