Old 04-16-2021, 07:06 AM   #51
leecatd8209
Originally Posted by Alex Mcknz View Post
The progress looks good, but it seems like you have a lot of things to do before you get to finish it.
Such is life.
5 cars, a job, and a life make things take a long time.
leecatd8209 is online now   Reply With Quote
Old 04-18-2021, 09:30 AM   #52
leecatd8209
I've been pushing myself to do something with my projects every day, no matter how small. Not every day is a Volvo day, but I'm moving forward.
Got the rods and NA pistons into the block, front and rear seals in, and the oil pump and pan on.
Don't mind my garage. My life, and especially the garage, is lived in a constant state of near to full on chaos. It's exhausting and infuriating, but somehow I manage.
And awhile back I managed to finally give her a good wash and recharge the AC!
It's time to start robbing parts off the engine in the 760 in order to get this one buttoned up enough to set in place, as of now it's at least mobile, so I'm not looking forward to taking it out of commission with the way my motivation has been lately. This is also the point where parts I don't have on hand are going to be throwing me off. I already don't think I have o-rings for the oil filter extension, and the PCV parts I have are for a later car.
Not the time to dwell on what's gonna hold me up, though. Just gotta keep moving.
Old 04-19-2021, 09:00 PM   #53
leecatd8209
My daily "Sloppy hour" is making stuff happen faster than I anticipated
free image upload site
Old 04-19-2021, 11:08 PM   #54
whatshouldido
Haha sloppy hour ,
I need to follow suit with atleast an hour gettin sloppy on my projects !
Thanks for the inspo n good luck on the +t ! Its so worth kt!
---1991 volvo 745 turbo wagon
**m47 swap incoming !
--1977 244 360k+ miles all original
** drive till wheels fall off
whatshouldido is offline   Reply With Quote
Old 04-20-2021, 10:07 PM   #55
leecatd8209
Water pump, timing belt tensioner, and YoshiFab oil drain fitting installed tonight. The manifold is just hung for now, I forgot to order gaskets :(. Next I need to reclock the 15g, and mount the late 760 oil filter extension/cooler thermostat. I'm waiting on an IPD order with a cam in it. Once it shows up I can get it timed and get the front buttoned up. And once I get manifold gaskets I can wrap up the hot side as well.
Starting Thursday I have 7 days off, and I would LOVE to hear this run by the end of that. It's a lofty goal, and parts will probably hang me up, but even just getting this motor set in the car would be cool.
Old 04-21-2021, 07:47 AM   #56
leecatd8209
Since I'm moving from the T3 to a Mitsu turbo do I need to change the coolant hoses for the water cooling? Also I think the charge pipe couplings are a little different on the turbo side for the Mitsu cars.
Just about everything I'm using came off a 1990, so I think I'm safe ordering parts for that as opposed to the 1986 T3 car.
Lastly what's stopping me from using this do88 piping kit? FCP says it's only for 92-95 models
https://www.fcpeuro.com/products/vol...88-performance
Edit: late turbo cars have the intercooler inlet and outlet lower than the earlier ones.
Old 04-21-2021, 10:29 AM   #57
white855T
You can get the hoses from ipd or fcp. https://www.ipdusa.com/products/2088...-KIT26S-139570
