Old 04-26-2021, 07:35 AM   #26
nordmaschine
forced instruction
nordmaschine's Avatar
Any progress?
I'm looking at a BAU sitting on ma garage floor, too bad bellhousing isn't the same as Inline 5/6, so I'll have to cut and weld a Getrag...
Jetronic is romantic.
- '86 780 TDIc - Bertone #301
Whiteblocks
Old 04-26-2021, 12:19 PM   #27
petiww
petiww's Avatar
Any progress?
Or use a welded quattro gearbox and maybe a flipped rear end? Those boxies have long 5 and 6 gear ratios!
Well, nothing much to be speak of, and as long as brownie is not driveable, i wont really touch it.
I did however source a working NA D24 from a 244, and an unknown condition D24T that sat for 15 years. I plan to slap together a D24TIC from these for mot funkyness. I may just install it now before the tdi, it goes to inspection at the end of the year anyway. This way i dont need to swap engines back and forth, and can continue to build the custom tdi bits in an other engine bay. Sad that i accidentally drilled through my finger...
1980 Brown 244 GL
Old 04-28-2021, 11:19 AM   #28
v8volvo
Any progress?
Have you tried bolting up the D24 type bellhousing from a M46/47/90 to that BAU? Are you sure it wouldn't work?
IIRC the inline 5/6 pattern is very close to the Audi V6/V8 pattern. Not identical, but I think there is perhaps only one bolt hole that doesn't align? Supposedly it is close enough to successfully use it, and people have done so. With 11 fasteners on these, using only 10 seems to be ok.
One time I sold a D24 M46 bellhousing to a guy who was searching for one to use it to put a 4.2L gas Audi V8 into a Miata with a T5 trans -- apparently that is a known successful combination. See more related discussion in this thread: http://forums.turbobricks.com/showthread.php?t=357535
Not sure what you would have to do with flywheel and clutch setup since I believe the crankshaft depth in the bellhousing would probably not be the same even if the bell could bolt up. But that's a solvable problem, getting the engine and trans to mate is the big part. I guess clocking angle could be a factor too.
BAU motor, if you don't use it, maybe you can box it up and ship it to me. I'm trying to source one to put into my 2001 C5 Allroad. Found an AKN, AFB, and AKE all already here in the US with importers, but I would prefer to get hands on one of the later Bxx roller valvetrain versions.
OP, sorry for the thread discussion derail. Looking forward to seeing this project continue, lots of fun to watch so far!
86 745 D24T/ZF 340k lifted 2.5"
83 764 D24T/M46 145k
04 Audi Allroad 6MT 2.0 TDI
01 Audi Allroad 6MT 2.7TT
v8volvo is offline   Reply With Quote
Old 04-29-2021, 01:07 AM   #29
moise
moise's Avatar
i have 245 tdi, you can use D24 intake manifold, you will see big difference!
moise is offline   Reply With Quote
