Old 04-23-2021, 01:38 AM   #26
Xeroni
MPG?
Xeroni's Avatar
Replaced the junkyard cap and rotor with new ones. Helped my ignition breakup over 15 psi a little but it's still there. I have a summit racing ignition box and coil on the way, we'll see if that helps.
Still waiting for the local e85 pump to open up so I can stop driving an hour out to the nearest one. The OD button on the shifter rarely works so I'll need to see it I can remove it and deoxit. Being stuck in 4th+lockup sucks for spooling and 2nd is too much acceleration lol.
Also I seem to have lost idling vacuum, before it would idle at 19 inHG and now it's at 15/16. In drive it's even worse. Haven't been able to find any boost leaks but I'll need to make/borrow a leak tester to see.
1990 765T; sent off
1989 744T; parted out
1985 245; The Battlewagon;+t, B21/AW71L, back at it again with the megasquirt; sold
1994 945; it's 16v+t again
2020 Mustang GT; DD
2007 Crown Vic; lifted, minispool, off road beater
Xeroni is offline   Reply With Quote
Old 05-03-2021, 12:13 AM   #27
Xeroni
MPG?
Xeroni's Avatar
Chasing exhaust leaks.
New j pipe to manifold gasket
Fancy copper manifold gasket
Replaced some cracked belts
and finally a new fuel filter
Sounds like I got most of the leaks but I still hear a little leak as the boost builds up.
Old 05-03-2021, 06:48 AM   #28
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
nice! where did you get the copper gasket?
Old 05-03-2021, 04:21 PM   #29
Xeroni
MPG?
Xeroni's Avatar
KL Racing sells them, I wanted to grab an intercooler and hose kit but they've been out of stock forever.
Old 05-04-2021, 01:04 AM   #30
122power
dude
122power's Avatar
Hey do you want or need a b234 block? Or rods and pistons? Free if you want it. Crank also.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 05-05-2021, 12:18 AM   #31
Xeroni
MPG?
Xeroni's Avatar
Thanks but I don't need one. I still have the old engine from this car on the stand waiting for me to decide what to do with it.
Old 05-05-2021, 06:48 AM   #32
hk 40
hk 40's Avatar
Are you truly trying to give the block rods ,pistons, and crank away for free? Sorry I had to ask.
Hubert
Original Join date 5-21-2003
hk 40 is offline   Reply With Quote
