Old 04-19-2021, 07:17 AM   #1
sekokupu
Question G80 repair
Noticed that 940 locker does not engage sometimes, opened diff cover and saw that one little axle is missing one spline (that upper one: https://www.240turbo.com/G80MLocker-g80lo.jpg ).
How hard is that to replace, do I need to get whole carrier out or is there way to get those parts out without opening whole thing? Or maybe it's best to get whole working axle or finally get proper locker
sekokupu is offline   Reply With Quote
Old 04-29-2021, 02:32 AM   #2
FreeEMSFred
FreeEMSFred's Avatar
You'd probably need some proper machining experience to repair that and even then it'd not be worth it. Get yourself a trutrac with preload installed and don't look back.
Old 04-29-2021, 07:35 PM   #3
boxtoy
Can Trutrac be had with 3.54 Gearing
boxtoy is offline   Reply With Quote
Old 04-29-2021, 08:14 PM   #4
The Librarian
The 912A588 high preload Truetrac works with all Volvo 1030 & 1031 ring & pinions.
Old 05-04-2021, 04:46 AM   #5
FreeEMSFred
And presumably most or all 1041 and 1041K ring and pinions, too, right? :-)
Old 05-04-2021, 11:57 AM   #6
The Librarian
Yes, the 1041 and 1041K use the same ring and pinion as 1031. The 4 in 1041 indicates a G80 is installed.
Old 05-04-2021, 12:59 PM   #7
I have used J-26252 to pull those pins, but you could probably just punch it out.
