Old 04-27-2021, 01:53 AM   #1
HiSPL
HiSPL's Avatar
Default AC Knob. Will it work without the temp tube?
So I broke my Capillary tube on the AC knob. Will it still turn the AC on without that temp sensor?
I currently do not have AC and want to get it running. If the knob still works, but just won't cycle that'll be fine with me. I can manually do it while I'm fixing the rest of the system.
Beets taste like buttfeet.
88 244
06 XC90 V8
03 V70
HiSPL is online now   Reply With Quote
Old 04-27-2021, 12:41 PM   #2
I think it will turn the system on. But you won't have the thermostat affect. However, if you rotate the switch to max a/c that is supposed to bypass the thermostat affect and make the a/c run without cycling.
Old 04-27-2021, 12:54 PM   #3
HiSPL
HiSPL's Avatar
Oh snap! Thanks for that.
I have several other things to fix first, but that will make troubleshooting easier.
I doubt that here in Texas it will ever freeze anyway. I might just buy a later style rocker switch and replace my thermostat with an on/off switch.
Old 04-27-2021, 01:20 PM   #4
philski o'flood
philski o'flood's Avatar
hook up the late style switch like cleanflametrap shows
http://cleanflametrap.com/ac.html
and then remove and connect the 2 green wires from the back of the thermostat
together and throw the tube and thermostat away
philski o'flood is offline   Reply With Quote
Old 04-27-2021, 01:38 PM   #5
HiSPL
HiSPL's Avatar
Rock on. Thanks for the link!
