Old 04-28-2021, 01:16 AM   #1
BeaverMeat
BeaverMeat's Avatar
Default Mah speedo cable!
Half of the plastic locking sleeve/collar/ring/thingy broke on my ‘81 240 mechanical speedo cable to the cluster... it still speedo’s half-assed....Any repair suggestions? Duck-tape? Magnets? Voodoo magic?
Short of replacing the whole kit-and-kabotle, what can be done?
She’s built like a steakhouse but, she handles like a bistro.
Old 04-28-2021, 02:30 AM   #2
Mr. V
Mr. V's Avatar
You can try taping, or glue it for a permanent fix, but I'd suggest a new cable, or if money is tight, a used one from a wrecking yard.
Old 04-28-2021, 08:27 AM   #3
TestPoint
TestPoint's Avatar
A 40 year old used one is going to have the same brittle plastic issue as the one the OP broke.
Mine broke also. I repaired it by using some plastic hose and clamps.
Ford V8 Conversion Manual -
Old 04-28-2021, 01:16 PM   #4
BeaverMeat
BeaverMeat's Avatar
That’s right up my ally! I really don’t want to source a new cable and have to fish it through.
Old 04-28-2021, 08:14 PM   #5
I'd rig up some of that stainless steel duct tape from a hvac supplier and tape it on. That stuff is super tacky.
Old 04-28-2021, 08:23 PM   #6
TestPoint
TestPoint's Avatar
You will have to remove the cable from the transmission and pull a foot into the cabin behind the panel in order to connect it with any degree of nice.
Old 04-28-2021, 09:20 PM   #7
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
You can also just press fit it into the speedo. I've had cars where the collar went completely MIA. Cable's long enough that it'll remain in place for years.
@john242ti on IG
Old 04-28-2021, 09:22 PM   #8
BeaverMeat
BeaverMeat's Avatar
Too much work. I can sit in the passenger seat go inverted under the wheel.
