Old 05-01-2021, 12:45 AM   #26
1968 volvo
Post
Originally Posted by planetman View Post
Remove the secondary butterflies and the secondary throttle shafts and plug the holes in the manifold.
We've seen people unnecessarily drill, tap and install threaded plugs, while we have the correct size plugs that just need to be tapped in with a hammer.
If you look carefully you will see that Volvo did the exact same thing by using a tap in plug for the inner holes for each of the secondary throttle shafts.
In fact we used to re-purpose the used plugs from cracked manifolds and when that supply ran dry we bought them right from Volvo back when they were available and when that well ran dry, we sourced some from a supplier that made the right size plug.
FYI, you will need to remove the carbs to remove the secondary butterflies and if not already done, you should solder closed the decel valves that are built into the butterflies in the carburetors.
We also have carb base gaskets as they might tear when you remove the carbs.
Where can I get the plugs and gaskets? Seems like the way to fix it.
1968 volvo is offline   Reply With Quote
Old 05-01-2021, 01:37 AM   #27
planetman
planetman's Avatar
We've got them. $10.00 for 2 plugs and 4 gaskets plus shipping.
Eric
Torrance, CA 90502
Old 05-01-2021, 11:34 AM   #28
1968 volvo
I suppose for ten dollars, its worth a shot. Is your website High Performance Automotive Service? Or is it better to buy from you?
Old 05-01-2021, 12:10 PM   #29
spock345
spock345's Avatar
Planetman and his brother hiperfauto are the gurus for the OHV cars. Every time I had a problem their solutions worked the best.
1967 122s, B20F, M40
Old 05-01-2021, 12:42 PM   #30
planetman
planetman's Avatar
Both of those parts are on our website and you can place an order after registering, but you won't be able to pay as we have disabled the payment module.
To ensure accuracy, we found it necessary to interact with our customers. It is very easy to order the wrong parts due to the interchangeability of parts between the different Volvo models.
For example, it is not uncommon to find a B20 engine in a car that originally came with a B18 or even a B16 engine.
You can reach me through our website via our contact page below.
http://hiperformanceautoservice.com/contact_us.php
