Old 05-04-2021, 07:17 PM   #1
NonTurboBrick245
Default 1993 240 Odometer issues
I'm looking for advice / any fixes, I've replaced the odometer gear twice within the past 4k miles and it stops usually while trying to turn over more than 2 digits, like 99 to 100. Sometimes it sorts itself out but more often than not I have to replace the gear again
'93 245 - Daily
NonTurboBrick245 is offline   Reply With Quote
Old 05-05-2021, 04:02 PM   #2
This thread should help you. Are you handy with a soldering iron? That is the path you are probably on. https://forums.turbobricks.com/showt...ht=volvowagoon
There is also a lot of information on cleanflametrap.com.
Old 05-06-2021, 10:43 AM   #3
240Redblock
I had the same issue on my 86, the replacement gear was just loose enough to spin on the shaft when there was enough resistance. I just put a few dabs of locktite on the inside of the surface and have it a minute to get tacky, reinstalled and worked for over 5k miles since. This might be your problem easy fix...
D.D. 1985 245 N/A M46
1982 242 N/A M46
1982 245 N/A M46
1973 p1800 es w/2.1T - project
240Redblock is offline   Reply With Quote
