Old 05-04-2021, 10:44 PM   #1
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Default What does this hose do?
Vacuum hose from that grey thing
Old 05-05-2021, 12:15 AM   #2
That solenoid activates the EGR valve.
Old 05-05-2021, 07:31 PM   #3
Wilford Brimley
Ohh so that might be why I'm running a little wonky
Old 05-05-2021, 08:23 PM   #4
I think it may have to do with your work
Old 05-05-2021, 08:59 PM   #5
Wilford Brimley
I think you maybe right
Old 05-05-2021, 09:15 PM   #6
EGR won't cause a running issue. IF the EGR valve is stuck open the engine will probably stall at idle. These cars don't really have that problem. EGR just comes on at light throttle/cruise to lower NOX emissions.
I see a blow thru MAF, blow off valve, custom pipes, etc. If you rework the entire induction system and also put some different injectors in there, I would expect the car to run like crap. I have seen it tons of times over the decades here.
Old 05-06-2021, 11:33 PM   #7
Wilford Brimley
Its just running at 13.9 to 14 afr when it used to be 14.5-14.7....not a big deal just kinda random, I wouldn't say it runs crappy just a little rich...the thing rips otherwise
Old 05-07-2021, 12:00 AM   #8
Your brake fluid is low. Why?
Old 05-08-2021, 07:38 PM   #9
Wilford Brimley
Had a leak i discovered...its not low now
