Old 11-05-2007, 05:37 PM   #26
Volvorules
Has a Built Trans!
Volvorules's Avatar
Originally Posted by Mueller View Post
killed a few hours day in the shop...instead of working "on" the car and making real progress, I made a few parts that'll never be seen once installed
made 4 of these puppies tonight (only need 2 of course, giving a friend the other 2 for his 244)
Yeah, you better have tie rod spacers before you put those on. The bumpsteer with the blocks and no tie rod spacers is VERY dangerous. Ask me how I know....
Rob
Now with 1 Volvo (hers)
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 07-17-2008, 05:40 PM   #27
Mueller
Mueller's Avatar
time for an update.....
installed LH2.2 instead of the K-Jet.....put about 50 miles on a motor that has sat dormant for over 10 years before loosing all the water out of the radiator, compression test showed 0,0,0 and 30psi.
Pulled the head and wow, surprised the car ever ran....
I have a few motors to chose from in my garage to use, so time to look at them again and pick the best one....
Old 07-17-2008, 05:43 PM   #28
Mueller
Mueller's Avatar
Default 8v larger valves, pics and part numbers
Last edited by Mueller; 09-18-2008 at 02:30 PM.. Reason: messed up, posted wrong part numbers :)
Old 07-17-2008, 05:47 PM   #29
Mueller
Mueller's Avatar
Default World Class T5 transmission, I "need" an overdrive !!!
the 242 currently has an M45(?) 4 speed with no overdrive....freeway driving at "normal" speeds is spinning the motor more than I would like...so I might as well install a better transmission while I have the motor out...time to take some dimensions and make an adapter plate.....
'90 Mustang 5.0 application
still a world class, however it is from a Ford 2.3 Turbo T-Bird, not the best gear ratios, but for an n/a car, not too bad....if they totally suck, I can upgrade to better ratios down the road...
Old 09-18-2008, 02:33 PM   #30
Mueller
Mueller's Avatar
US Mail just showed up delievering goodies....
pistons and rods from JVAB, motor is an N/A so I went with flat tops and a 1mm overbore
Old 09-18-2008, 03:39 PM   #31
Steve and his 244
Steve and his 244's Avatar
Niiice!! Cant wait to see some progress!
Steve and his 244 is offline   Reply With Quote
Old 09-18-2008, 03:41 PM   #32
pooprah
Guest
woot
Old 09-18-2008, 11:07 PM   #33
Crazychopstick
(/// _ - )
Crazychopstick's Avatar
Location: Receiving Transmission from David Bowie nipple antenna
Needs moar black wheels.
Does the T-5 need to be rebuilt?
Crazychopstick is offline   Reply With Quote
Old 09-19-2008, 03:18 AM   #34
Mueller
Mueller's Avatar
NEVER !!!!!
The transmission looks to have been rebuilt before (non-factory sealant), however, I already bought a complete kit before taking it apart and might as well freshen it up again.
Gears are in great shape !!!
Old 10-26-2009, 03:01 PM   #35
Mueller
Mueller's Avatar
decided to address my lack of limited slip differential.....as per JohnV's recommendation, I sourced a Toyota truck rear end (open diff) and a Toyota Supra center diff assembly.
The Supras come with a nice clutch pack type LSD, this is a true limited slip and should be a lot better than the G80 route.
For the truck rear end, I picked up the wrong one...this one has the 7.5" ring and pinion, I should have picked up the 8" unit, we'll see how this one holds up 1st, I think it'll be fine for my less than 300hp current goals.
The axle is the same width as a 240, 55" mounting surface to mounting surface, drum brakes to be replaced by discs.
Old 10-26-2009, 03:49 PM   #36
stylngle2003
stylngle2003's Avatar
will the stooprah diff fit in the smaller yota rear?
-Billy
1990 Mazda Miata (track toy)
Old 10-26-2009, 03:54 PM   #37
Mueller
Mueller's Avatar
not this Supra one, I'll have to get one from a MKII, '82-'85, they called them Celica Supras, the ones with the plastic fender flare extensions....
Old 11-02-2009, 04:34 PM   #38
you got the 8" axle right? any updates on the weight?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-03-2009, 12:37 AM   #39
Tom Wiley
What are the power goals for this car? 225 to the ground?
Tom Wiley is offline   Reply With Quote
Old 06-13-2011, 09:39 PM   #40
Mueller
Mueller's Avatar
wow, has it really been that long since I've worked on the car??
moved car from driveway and into the garage over the weekend.....plan is to try and work on it for a few hours per night.
A few pics of new wiring harness on top of the car, this is a 20 circuit universal unit, now to figure out how I want to route everything and what connectors to use
Old 06-16-2011, 09:02 AM   #41
Mueller
Mueller's Avatar
Pulled the stock wiring out last night, 12 pounds,
Old 06-16-2011, 09:06 AM   #42
Mueller
Mueller's Avatar
Engine getting a little more bare..
Old 06-16-2011, 09:09 AM   #43
Mueller
Mueller's Avatar
Pulled the dash, w/pad and gauges it weighs 17 pounds
Old 06-16-2011, 09:12 AM   #44
Mueller
Mueller's Avatar
Going shopping for an a/c setup soon. The vents and tubes for the heat and ventilation are full of dirt and dust...need a good cleaning
Old 07-10-2011, 06:16 PM   #45
Mueller
Mueller's Avatar
Old 07-11-2011, 02:07 AM   #46
Mylesofsmyles
I hope something fun and aspirated is going in there.
Old 07-11-2011, 02:25 AM   #47
Lord_Athlon
300+ Clurb
Lord_Athlon's Avatar
Most engines aspirate
Yet Asher here went with...
Old 07-11-2011, 12:11 PM   #48
Mueller
Mueller's Avatar
Stockish B230F for now.... have something fun and different planned, no pictures until it is developed a little more to make sure it works okay.... it'll get laughed at if talked about without proof of concept
Old 07-11-2011, 12:20 PM   #49
Mylesofsmyles
No, you'll just get laughed at for taking FOREVER!!!!!!!!!!!!!
Old 07-11-2011, 12:41 PM   #50
Mueller
Mueller's Avatar
get married and have a few kids...see how long it takes to get anything done
