Old 05-07-2012, 01:02 AM   #76
Mueller
Mueller's Avatar
Played in the garage again today, still working on the rear suspension, making progress slowly.
Pics top to bottom:
Axle in vice, I have to remove the CV joint by smacking the inner part to force it compress a spring on the end of the shaft, no way to access the spring since it's inside the unit.
Tri-lobe, 930 Porsche CV and stock T-bird CV with t-bird axle below.
Bins full of parts
Naked center pumpkin housing. needs to be sandblasted and painted or powder coated next.
Uprights, housings for spindles, the one on the has been soda blasted 1st, but I didn't like the finish so I sand blasted afterwards.
Old 05-07-2012, 01:08 AM   #77
I gave you 5 stars for making progress, ugly or not.
Steady as she goes..
Old 05-07-2012, 02:11 PM   #78
Mueller
Mueller's Avatar
thanks, feels good to see some sort of progress being made
Old 05-09-2012, 02:08 AM   #79
Mueller
Mueller's Avatar
Took the ring gear off my old flywheel and put in on the new steel billet JVAB unit tonight.
Old 05-09-2012, 02:17 AM   #80
Mueller
Mueller's Avatar
Soda blasted the seams in the engine bay, I need to take the brake booster out to access parts of the bay a little better.
I was going to start welding yesterday but my MIG was out of gas :( Not something I want to weld with the TIG or oxy/acet setup.
I found another stress crack on the car, 2 actually, the doors where the window frame and door body meet up.
Old 05-09-2012, 10:21 AM   #81
towerymt
the real Towery
towerymt's Avatar
The flat flywheel mikeP lightened for me had the edge cut down at an angle using a brake lathe. Same with my aluminum flywheel, not much material outside of the pressure plate bolt pattern.
We had a friend mill holes in a flat flywheel for our LH2.4 lemons car. Just drilled into the edge, but didn't cut all the way out to the face of the flywheel. thought it might be an issue cause the sensor wasn't perfectly centered over the holes, but it works fine. actually he might have used a mill table under the drill press because the flywheel was held vertical. regardless, it worked out.
Old 05-15-2012, 12:52 AM   #82
Mueller
Mueller's Avatar
Doing something some of you geeks might find interesting...sending off these 3 "samples" to a lab so they can do a little spectrographic analysis on them so I can get a close or perfect match for welding....I'm guessing 1030,1080 or thereabouts, for sure nothing like 1018 or 4340
Left to right....CV joint on wheel side of axle assembly, tri-lobe on the diff side of axle assembly and finally the axle in the middle.
Old 05-15-2012, 01:13 AM   #83
55superbeetle
Very cool to see some progress! I'm getting ready to go through my 8.8 and install some 3.08 gears in preperation for the turbo.
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
Old 05-15-2012, 01:14 AM   #84
Mueller
Mueller's Avatar
Got an "extra" traction-loc?
Man, that thing is a beast, I talk about your car at least once a week
Old 05-15-2012, 01:26 AM   #85
55superbeetle
Don't have any extras but half off weekend is coming up at pick n pull! I have just been collecting parts for my car but haven't lost a race yet. I can't wait to get the turbo on and start racing some of the real cars around here.
Old 06-17-2012, 01:06 PM   #86
Mueller
Mueller's Avatar
I ended up getting a Traction-lok from ebay at a decent price.
I'm rebuilding it this week, just got my new CF clutch pack for it and all new bearings.
Good bye open housing....
Taking the bearings off the new-to-me traction-lok unit.
Old 06-19-2012, 01:56 PM   #87
oooo clutch packs. my favorite!
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 06-27-2012, 06:19 PM   #88
Mueller
Mueller's Avatar
Yep, I don't mind that popping sound they make
For my half shafts, I decided to bite the bullet, converting the axles to 930 CV joints on both ends of the axles, Chromoly flanges have been ordered as well as new German CV joints.
The tricky part will be getting an axle in the correct length that I can order from a catalog. Custom length units cost about $100 more per set. Looking at about $200 for chromoly axles (pair)
Old 07-02-2012, 10:58 PM   #89
Mueller
Mueller's Avatar
Slow at work so I took the day off to work on the car....did some seam welding in the engine bay...came out ugly, oh well, another project for another day to fix once the car is a driver and I have some down time.
Started to take the paint off the hood to repaint the underside...
US Mail came today with a package, new chromoly flanges to be mated to the old parts...
Old 07-02-2012, 11:02 PM   #90
Mueller
Mueller's Avatar
Oxy/acet welds...my MIG welder is acting up, the welds just wouldn't come out decent..possible too much voltage drop from having to run a long extension cord due to car facing the wrong direction down the driveway..??
Old 07-03-2012, 01:05 AM   #91
shaved240
shaved240's Avatar
subscribed
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
Old 08-11-2012, 06:08 PM   #92
volvonyc
wheres the updates??????????????????????????
volvonyc is offline   Reply With Quote
Old 08-26-2012, 11:42 PM   #93
Mueller
Mueller's Avatar
I bought this B230F a few years ago, decided to finally clean it up and inspect it to see how bad it is. Wow, I think I scored on this one, while dirty on the outside, the oil looked new, no dirt/grime or sludge once I popped off the valve cover and the combustion chamber looked great as well. I'm guessing someone had the motor rebuilt and only put a few thousand miles on it?
Ignore the Honda thing, easier to link from here than upload to PB..it's for the poi
Old 08-27-2012, 03:18 AM   #94
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
what a cool license plate for that car :D
mueller... you need to work faster.. even my car had more progress ;)
Old 10-08-2012, 01:23 AM   #95
Mueller
Mueller's Avatar
A clean pumpkin, just in time for October.
New Carbon Fiber clutch pack for the Limited slip.
All new bearings, replaced the crush washer with a solid washer for the pinion.
Next will be the axles.
Old 10-10-2012, 04:44 AM   #96
2fast242gt
Do you have a cobalt?
More more!
1983 242dl
*6.0 lq4 swaped* Build thread
Old 10-30-2012, 01:36 AM   #97
Mueller
Mueller's Avatar
fired up the computer, started laying things out again...
Old 10-30-2012, 09:21 PM   #98
Homer
OEMplus++
Homer's Avatar
I'll take one IRS setup please.
-Jacob:
2017 allroad - Comfy DD
Homer is online now   Reply With Quote
Old 10-30-2012, 09:48 PM   #99
towerymt
the real Towery
towerymt's Avatar
I'm going to need 2.
Old 10-31-2012, 02:26 AM   #100
Mueller
Mueller's Avatar
^Plenty of other areas I'd throw my time and money at if I was you.
