Old 09-03-2018, 10:41 AM   #501
4master
What a machine!
4master is offline   Reply With Quote
Old 09-03-2018, 12:25 PM   #502
Atom D&D
Atom D&D's Avatar
Originally Posted by vwbusman66 View Post
I wish...
Originally Posted by slow240 View Post
ORLY???? You thinking of a turbo 5?
Originally Posted by Beachee View Post
B5254, with or without turbo?
Originally Posted by matt b View Post
You're really going to piss off purists at car shows now!
Had an opportunity to see the car in Seattle a couple of weeks ago: so, so nice!
Originally Posted by 4master View Post
What a machine!
Yeah, Iím gonna swap in a turbo whiteblock at some point. Probably the most cost effective swap I can do (also familiarity plays a role). The head is off my brotherís C30. It skipped time and bent a bunch of valves. Just setting it there to check sizing. I would boost the M20B25, but there is zero room for an intercooler. With one less cylinder I might be able to make room. Plus, what kind of confusion havoc would that cause? Vintage Volvo body>E30 chassis>modern Volvo engine.
Iím in no hurry though. Iím enjoying the car after six years of driveway ornament status. Iíll start amazing parts and when the time is right, then Iíll mess with it
Atom D&D is offline   Reply With Quote
Old 09-05-2018, 04:42 PM   #503
Atom D&D
Atom D&D's Avatar
I gotta travel to El Paso for work next week, so I’m gonna try and get some glass work done before I go so it can have a nice long cure time.
Old 09-05-2018, 09:19 PM   #504
Atom D&D
Atom D&D's Avatar
Making caps for the end of the dash to meet up with the door tops.
Old 09-05-2018, 11:32 PM   #505
Atom D&D
Atom D&D's Avatar
I’ve tried doing some research, but it’s difficult to find anything firm. Does anyone know if you can you run a RWD manual whiteblock swap on the OE ECU (ME7?)? When I do the swap I want to do it on the cheap (of course) and love the idea of the OE reliability and all the engineering/tuning that goes into the stock system. Idle, tip in, lean cruise, all have already been worked out. You can find P2 T5 somethings for cheap all the time.
Old 09-05-2018, 11:33 PM   #506
Jack
junkman
Jack's Avatar
contact lucky at ARD
I love you even more Jack.
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 09-05-2018, 11:44 PM   #507
doucheNozzle
doucheNozzle's Avatar
Originally Posted by Atom D&D View Post
Iíve tried doing some research, but itís difficult to find anything firm. Does anyone know if you can you run a RWD manual whiteblock swap on the OE ECU (ME7?)? When I do the swap I want to do it on the cheap (of course) and love the idea of the OE reliability and all the engineering/tuning that goes into the stock system. Idle, tip in, lean cruise, all have already been worked out. You can find P2 T5 somethings for cheap all the time.
Yes. Talk to Hilton, not that dumbass Lucky at ARD.
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
doucheNozzle is online now   Reply With Quote
Old 09-06-2018, 12:10 AM   #508
Jack
junkman
Jack's Avatar
idk I had mixed feelings with him years ago on p80 stuff but thats all that I know
Old 09-06-2018, 12:48 AM   #509
doucheNozzle
Yea he has no idea what heís doing.
Old 09-06-2018, 12:44 PM   #510
Lord_Athlon
300+ Clurb
Lord_Athlon's Avatar
It would be easier to do 4.4 and ditch the ETM
Yet Asher here went with...
Old 09-06-2018, 01:41 PM   #511
andyb5
andyb5's Avatar
If you took the ECM from a P2 car the complications would arise from the CANBUS network and the other modules in the system that are required to make the system operate without any error codes. But from a mapping standpoint, I would expect that minor tweaks are all that would be required to tailor a stock T5M tune to the car - for the most part a manual is a manual, doesnít matter if itís a M56, M66, M90 or some other transmission.
A 99/00 turbo would be a good starting point because the ECM doesnít communicate with nearly as many CANBUS modules as a P2. 00 would be preferable due to the limited nature of the memory/available maps in a 99 ECU. The 99/00 isnít as sophisticated as the later P2 ECMs but theyíre both still ME7 which offers a huge upgrade in control over M4.4.
I would also recommend avoiding ARD, a few too many of my friends had problems with their tunes on a ME7 car for me to encourage anyone to work with them for a tune.
00 V70 R - 04 B5234T9 w/ 18T, M66, Stevo tune, CX Racing coilovers, 996TT BBK
andyb5 is offline   Reply With Quote
Old 09-07-2018, 11:19 AM   #512
Atom D&D
Atom D&D's Avatar
Ok, so Craigslist ad says “rebuildable core. needs headgasket”. I buy it with intentions of swapping the head onto my brother’s C30 with bent valves. He decides that he “probably” wants to just have his head rebuilt so that he has a known good part, rather than used. I get the engine to the shop and break it down. I’m not seeing any bent valves, obvious head gasket failure, cracks in the head or cylinder. I text the guy back to ask how he knows it was a bad head gasket and the response I got was
“The heater hose had a leak. And he drove it for a couple days like that. Before he decided to check the coolant level and add more. He said it would over heat after he topped off the coolant. He than took it to a shop who allegedly diagnosed a failed head gasket. It was cheaper to swap in a junk yard engine than repair the heat gasket. That's when I got the car. I didn't diagnose any further and pull the motor.”
Thoughts? The plugs were out, so I’m assuming someone did a compression test.
I wiped the lips down with acetone and a grey scotchbrite to check for cracks:
Cylinder 5 (both sides)
Cylinder 4 (both sides)
Cylinder 3 (both sides)
Cylinder 2 (both sides)
Cylinder 1 (both sides)
Cylinder head (I wiped the gasket surface down with acetone and scotchbrite to look for cracks or corrosion):
cdn.com/20180907/cd5de15f9d5de1c0e58a5e65ed6ba080.jpg[/IMG]
Head gasket (untouched)
Warped head?
Old 09-07-2018, 12:04 PM   #513
Can you feel pitting at the top of 4 or does the camera play tricks?
Old 09-07-2018, 12:09 PM   #514
Atom D&D
Atom D&D's Avatar
Didn't catch my nail.
Old 09-07-2018, 02:40 PM   #515
Atom D&D
Atom D&D's Avatar
Head warped .013" according to my machinist's ruler and feeler gauges.
Old 09-07-2018, 02:52 PM   #516
doucheNozzle
That was going to be my question. Check the head and block. Open deck is picky.
Old 09-10-2018, 01:27 PM   #517
PAULDRIVER
Which trans will you use Atom ?
Or is it posted and id missed it ?
Keep up the good work !
WHALE OIL BEEF HOOKED
(use Irish accent)
PAULDRIVER is offline   Reply With Quote
Old 09-10-2018, 04:48 PM   #518
Atom D&D
Atom D&D's Avatar
Getrag 260 so I can keep the rest of the BMW stuff. Still working out the details on how Iím gonna do it exactly.
Old 09-10-2018, 05:10 PM   #519
Jack
junkman
Jack's Avatar
Come buy my e36 m3 engine or e46 m3 engine instead
Old 09-10-2018, 05:26 PM   #520
Atom D&D
Atom D&D's Avatar
$500?
Old 09-10-2018, 06:17 PM   #521
Jack
junkman
Jack's Avatar
That’s what I paid for both with transmissions
Old 09-10-2018, 07:09 PM   #522
Atom D&D
Atom D&D's Avatar
Thatís what I paid for both with transmissions
Soooo.... Iíll take that S54 w/trans for $500 and you can keep the S52 for free?
Old 09-10-2018, 07:11 PM   #523
Jack
junkman
Jack's Avatar
Local pickup
Old 09-10-2018, 07:13 PM   #524
Atom D&D
Atom D&D's Avatar
Local pickup
Is the ass cheek of history right next to the taint of tomorrow?
Old 09-10-2018, 07:28 PM   #525
A Whale's Vagina, as named by the Germans.
