Old 11-27-2018, 11:50 AM   #651
Atom D&D
Atom D&D's Avatar
Few more things done:
-thermostat spacer to add an E30 temp sender for the dash gauge.
-upper intake spacer to clear taller injectors (S40 injectors are short and I’ll probably just run greens for now)
-hardlines for turbo coolant in/out. Had to order some different -10 fittings for the drain and still waiting on a straight -4 for oil feed as well as the time to weld the -4 and -10 steel fittings to the OE hardlines.
Oh, also added some 3/8” stainless bar to support the turbo
Atom D&D is offline   Reply With Quote
Old 11-27-2018, 04:40 PM   #652
Beachee
Beachee's Avatar
Default Copper
:-) You like the copper tubes? :-)
From what year are that intake? Volvo?
Beachee is offline   Reply With Quote
Old 11-27-2018, 05:08 PM   #653
Atom D&D
Atom D&D's Avatar
I like the vintage look. Brass and copper.
Ď05 S40 T5
Old 11-27-2018, 06:00 PM   #654
M.H. Yount
M.H. Yount's Avatar
I don't think the copper will see temps or pressures where work hardening is an issue. Cu/Ni (cunifer) is also an option - and polishes up just about as nicely as copper, although not as 'pretty' a copper color. The lines look nice. I think we all know that the aesthetic approach taken on this project has always been different and interesting -- in the best possible way. Cool stuff.
Old 11-27-2018, 08:56 PM   #655
Atom D&D
Atom D&D's Avatar
Yeah, I’m not sweating it too much. Also, it’s just water. If it cracks it won’t be spraying hot oil all over the turbo.
Old 11-27-2018, 09:33 PM   #656
M.H. Yount
M.H. Yount's Avatar
Or even spraying it. (Chuckle)
Old 11-28-2018, 06:34 PM   #657
Atom D&D
Atom D&D's Avatar
Made an oil pressure block for the dash light and ECU. I used nickel copper brake line. I welded a -4AN fitting to a turbo banjo line that threaded into the OE oil pressure sender port.
I added DEI titanium wrap to the up pipe to keep the gasses hot and keep all the other hoses nearby safe. I also added an 1/8” NPT port near the turbine inlet. My tuner says we can put a pressure sender there (with some tube to insulate from the heat) to get a feel for turbine sizing and pressure ratio (or something like that).
Old 11-28-2018, 06:43 PM   #658
Sweet!
Btw I can't wait to see progress of your upcoming paint projects
Old 11-28-2018, 06:47 PM   #659
Atom D&D
Atom D&D's Avatar
Sweet!
Iíll let you post the pictures of that.
Old 11-28-2018, 07:40 PM   #660
doucheNozzle
doucheNozzle's Avatar
What are you doing for ECU/tune?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 11-28-2018, 08:37 PM   #661
Atom D&D
Atom D&D's Avatar
MS3
I actually bought it to use on the 16v Penta setup but never made it that far.
Old 12-22-2018, 09:26 PM   #662
Atom D&D
Atom D&D's Avatar
Been a while since I posted anything. Just working on dumb detail stuff. Alternator mount.
Made a floor mount shifter since I’m switching to an early trans and don’t want to use the sheet metal shifter carriage
Remains to be seen how well it works.
Throttle body adapter to shift the angle and to use a Volvo 960 cable 65mm throttle body
Grabbed a backup bellhousing so I can make a backup trans if needed.
Machines some caliper piston masking plugs for a set of Volvo R calipers I’m throwing custom paint at
Made a custom bed side table for my wife for Christmas.
Not pictured
-got an OEM S40 engine harness to mod
-got all the clutch bits final assembled
-got the trans attached for last time
-made FPR mount
-made IACV mount
-started fabricating heater hose hard lines
Old 12-22-2018, 11:15 PM   #663
M.H. Yount
M.H. Yount's Avatar
I'm sure I'm missing something - with engine/tranny able to move relative to the body, how will that body mounted shifter accommodate the movement?
Old 12-22-2018, 11:30 PM   #664
Atom D&D
Atom D&D's Avatar
I intend on making an adjustable selector linkage to get the resting angle of the shifter arm where I want it, but the ball pivot at the transmission means it shouldnít change much from trans cage movement. Any fore/aft movement is is translated in reverse motion at the shift knob. Axial rotation translates to similar movement of the shift knob (multiplied by the deflection at the ball pivot).
With a standard cage-to-trans mounted shifter, when you move the shifter left/right, the shifter below the pivot ball swings out (left right) rotating the selector at the trans. Iím allowing for that movement in a reverse order. It might cause more interior shifter movement as the engine torques, but shouldnít bother me. As with everything else, Iíll see how it works and toss it if I donít like it.
Old 12-22-2018, 11:42 PM   #665
Atom D&D
Atom D&D's Avatar
Here’s a couple that already exist in the market. I just built my own by welding a piece of the OEM cage in place as opposed to CNCing a complete replacement.
Old 12-23-2018, 07:51 AM   #666
Beachee
Beachee's Avatar
Great work, as usually. Love your work in details.
Merry xmas.
Old 01-03-2019, 05:20 PM   #667
Atom D&D
Atom D&D's Avatar
Heater tubes and a glamour shot
Old 01-03-2019, 05:55 PM   #668
Hey look, more porn
Old 01-03-2019, 11:18 PM   #669
M.H. Yount
M.H. Yount's Avatar
How did your bride like the bedside table?
Old 01-04-2019, 12:17 AM   #670
Atom D&D
Atom D&D's Avatar
She loves it. Iíll try and get some pics later. She likes that itís at the same height as the bed so she doesnít have to reach down a bunch to get her coffee.
Old 01-04-2019, 06:14 PM   #671
Atom D&D
Atom D&D's Avatar
Ordered a new shirt for show season this upcoming year. Seems to fit my build well.
Old 01-04-2019, 06:37 PM   #672
R32RennSport
Outlaw Amazonian
R32RennSport's Avatar
Must buy right there! That's classic!
Steven
1966 Outlaw Volvo Amazon, 2004 VW R32 Golf
R32RennSport is offline   Reply With Quote
Old 01-04-2019, 08:46 PM   #673
M.H. Yount
M.H. Yount's Avatar
My daughter grew up with the Muppets/Swedish Chef - she immediately set about trying to find that tee...
Old 01-04-2019, 09:12 PM   #674
Atom D&D
Atom D&D's Avatar
https://www.thebeauteeful.com/swedish-chef
Old 01-05-2019, 12:14 AM   #675
M.H. Yount
M.H. Yount's Avatar
Gracias.
