Old 05-16-2014, 08:15 AM   #1
Glocksrox18
Default LSD rear and diff ratio swaps
88 245 with a b230ft, hy35w, and soon to be t5z trans. The previous owner of the car swapped a g80 in but I still get one tire fire from a dead stop. I'm not even sure what ratio the rear is that he put in but for the hearing of the trans, I feel a 4.10 would be a perfect match.
Here are the ratios
1: 2.95
2: 1.94
3: 1.34
4: 1.00
5: 0.63
At 6800 rpm with 4.11 rear
1: 42 mph
2: 63 mph
3: 91 mph
4: 122 mph
5: 194 mph
My question is.. If I don't have a 4.11 rear right now, what parts would I need to swap it out? I'm looking into a Detroit locker or something aftermarket and strong. Not another g80. Other than the LSD itself... What parts do I need for the swap?
Thanks,
John
2005 S60R M66 - K24/27 Hybrid
1983 242 GLT Turbo M46 - 20T
1996 855R M56 - 22T/Built Motor/Quaife/Big turbo soon
1988 245+T M46/230FT/LH 2.4/HY35W - Crushed
FEEDBACK
Glocksrox18 is offline   Reply With Quote
Old 05-16-2014, 08:38 AM   #2
noz-e8tr
noz-e8tr's Avatar
Here is some good info. Perhaps it will have the stuff you are looking for..
Dave's Page
noz-e8tr is offline   Reply With Quote
Old 05-16-2014, 08:39 AM   #3
Lando
Arthur Digby Sellers
Lando's Avatar
Originally Posted by Glocksrox18 View Post
88 245 with a b230ft, hy35w, and soon to be t5z trans. The previous owner of the car swapped a g80 in but I still get one tire fire from a dead stop. I'm not even sure what ratio the rear is that he put in but for the hearing of the trans, I feel a 4.11 would be a perfect match.
Here are the ratios
1: 2.95
2: 1.94
3: 1.34
4: 1.00
5: 0.63
1: 42 mph
2: 63 mph
3: 91 mph
4: 122 mph
5: 194 mph
Thanks,
John
Eaton TruTrac should bolt to any of the dana 30's. You will have to figure out a solution for your speedo tone ring. There is a thread on how to install a trutrac in the articles section.
Originally Posted by 11110000 View Post
I didn't think there was anything to the whole 7/9 thing, but I have to say that my 745T is the only Volvo I've owned that blew up and self-immolated.
Lando is offline   Reply With Quote
Old 05-16-2014, 10:14 AM   #4
tt460
tt460's Avatar
I just got a TrueTrac and am going to be figuring out the tone ring. Are there any off-the shelf tone rings that I can buy to weld onto the diff or am I going to have to have to fab my own?
87 Volvo 745T
lambdatuner.com
tt460 is offline   Reply With Quote
Old 05-16-2014, 10:46 AM   #5
noz-e8tr
noz-e8tr's Avatar
Check out the link I gave above. Mikep was able to grove the TruTrac to work.
Originally Posted by From Daves Page
"I cut grooves with a die grinder and cutoff wheel. It was so easy and worked so well that I only do it that way now. The grooves need not be wide. The count just has to be the same. I think it's 12 grooves for the speedo. I'm not sure of the count for ABS. You can adjust the clearance by sliding the cover up or down, or by using a press in extreme cases."
Old 05-16-2014, 01:17 PM   #6
David244turbo
there are speedo rings for those truetracs. you only have to order them. i dont know where YOU can get it from becouse in sweden i bought my truetrac + speedo ring from www.bakaxel.se
you just need to weld it on and push the sensor out some millimeters and it will work.
depending on if you got ABS or not there are 2 different. i used this http://bakaxel.se/hastighetsmatarkrans.html in my 240(no ABS)
this one is for the ones with ABS
http://bakaxel.se/hastighetsmatarkrans-279.html
David244turbo is offline   Reply With Quote
Old 05-16-2014, 01:42 PM   #7
tt460
tt460's Avatar
The grooved method is compelling... I never would have considered that before, but I think I'll be giving that a try. Either way it looks like I'd need to void the warranty of the diff by either welding or grinding on it.
And sorry for hijacking your thread Glocksrox... But I think the best option is a TrueTrac for a differential. The G80 is a really great daily-driver differential, but not a performance diff. A TrueTrac is a really strong no maintenance differential.
Old 05-16-2014, 01:52 PM   #8
John V, outside agitator
But they "differentiate" pretty regularly when driving with any vigor like even hard cornering on dry..very readily on wet/loose...
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 05-16-2014, 02:01 PM   #9
Glocksrox18
I'm looking to replace the blown g80 I have now with an upgraded diff. I'm hoping to find a 1031 rear and throw 4.10 gears in with a true track
Old 05-16-2014, 03:14 PM   #10
You CAN shim the hell outta the tru-trac..Find the belleville wahers and shim 'em up.
Win win.
