90volvo
- May 27, 2017
- Eldorado Springs Mo.
I have 90 Volvo 240 +T. I have picked up a kjet intake that has the injector boss and mounting tabs. I have searched and searched but havent came up with answers. Heres my questions.
1. Fuel rail- found where someone used a b234 fuel rail, good luck finding one of those. Any ideas of what will work without a bunch of hacking.
2. Throttle linkage and cable. Found someone that used 82 throttle cable. NP there you can still buy them. But need idea of what to use for the rest of the setup.
3. I have an automatic trans. So, need way to attach the trans. pressure cable. Which if I get the throttle linkage figured out then the trans cable probably fit too. Hope I dont have to drop the pan.
4. My injectors seem to be reseased a quite a bit. Does the intake require different injector than the original style b230.
*** Is this intake worth all this trouble? Running b230 with RSI stage 1 cam- Npr IC- 3in. EXhaust- 19T turbo 20lbs boost- E85 chipped- AW71 trans-Big Thanks for any help.
